Station Pseudobridge SETUP
Guys,
I have very simple setup: WIFI - MAP Lite -Ethernet cable - HMI Panel. Station pseudo bridge. Used to work 2 years ago with different SSID. Configuration:
model = RBmAPL-2nD
serial number = CF290CE910C9
add admin-mac=48:8F:5A:28:F3:7B auto-mac=no name=bridge1
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
add name=LAN
add authentication-types=wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm
mode=dynamic-keys name=Home supplicant-identity="" unicast-ciphers=
tkip,aes-ccm wpa2-pre-shared-key=****************
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors
frequency=2462 installation=indoor mode=station-pseudobridge
security-profile=Home ssid=XXXXXXXXXXXX station-roaming=enabled
wireless-protocol=802.11
add bridge=bridge1 interface=ether1 trusted=yes
add bridge=bridge1 interface=wlan1 trusted=yes
set discover-interface-list=*2000011
add interface=ether1 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridge1
add address=XXX.XXX.XXX.32/24 comment=defconf interface=bridge1 network=
XXX.XXX.XXX.0
Any errors found?
Thank you!
And the question/issue is ???
Not the “years” or the “SSID” is important for changes here, but the ROS version could change some things.
e.g. Like MT DHCP server over station-pseudobridge has DHCP lease difficulties since 6.38 (http://forum.mikrotik.com/t/ros-6-38-serious-dhcp-server-problem/105259/1)
DIdn’t say this is happening here, but it could be this. Is the client device using DHCP? Then test first with a static IP address.
“pseudobridge” needs the client to communicate first, before it is reachable
Did the wifi connect? (SSID security could have been changed in 2 years).
Is that admin-mac still unique?
If the host AP for the mAP is also a MT, then use wifi mode “station bridge” , not “station pseudobridge” as needed only for connection to other AP brands.
Use “station bridge” if you can, far superior to “station pseudobridge”. “Station bridge” with Mikrotik’s is full 4-address mode wifi (transparent like ethernet connection)
Hello, bpwl,
good to hearing from you. In fact, I remember you helped me more than 2 years ago with this setup. (Topic: Home WIFI instead Mikrotik Wifi to Ethernet issue". The device is the same, literally.
No DHCP involved here.
What must be changed in the configuration, if I shift to station bridge?
Of course, the problem is that I cannot communicate with HMI through WiFi with HMI design software or SCADA.
I changed the setup to station bridge. It does not work either. Here is registration log:
[admin@MikroTik] > /interface wireless registration print stats
0 interface=wlan1 mac-address=48:77:46:85:6B:9A ap=yes wds=no bridge=no
rx-rate=“78Mbps-20MHz/2S” tx-rate=“26Mbps-20MHz/1S” packets=1350,2
bytes=159961,120 frames=1350,4 frame-bytes=162681,400 hw-frames=2865,1650
hw-frame-bytes=448079,262419 tx-frames-timed-out=0 uptime=3m59s
last-activity=10ms signal-strength=-64dBm@1Mbps signal-to-noise=46dB
signal-strength-ch0=-71dBm signal-strength-ch1=-65dBm
strength-at-rates=-64dBm@1Mbps 0ms,-68dBm@HT20-4 2m26s510ms,-68dBm@HT20-7
2m32s170ms
tx-ccq=67% p-throughput=24276 distance=1 802.1x-port-enabled=yes
authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
management-protection=no wmm-enabled=yes
tx-rate-set=“CCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-15”
[admin@MikroTik] >
And the log print:
2m32s170ms
[admin@MikroTik] >
Any thoughts?
Forgot about your previous setup. And here I’m missing information.
This registration printout makes me think this is not connected to a MT AP with wifi mode =“AP bridge” , and in which Bridge mode = “enabled” on the AP.
It that case with mode “station bridge” on the mAP Lite, the “bridge” part is still not activated.
The only way then is using the regular wifi possibilities, and that is the regular 3-MAC-address mode : sender - transmitter - receiver (missing the 4th address : destination)
So the wifi IP traffic is always terminated in the mAP Lite itself. You need to forward it to the destination with either dst-nat, if not a response on the masquerade NAT firewall rule.
Masquerade is what we do in a “Home AP” setup, where the IP is routed and masqueraded (what is using src-nat for outgoing traffic, and handling it’s responses), All IP traffic is using the mAP Lite’s IP address for all devices on the mAP Lite LAN (ethernet) side.
(Incoming traffic, iniated from the AP side, to a device on the mAP ethernet interface, must be explicitly forwarded with dst-nat in the mAP Lite. See http://forum.mikrotik.com/t/how-to-forward-dmz/35097/1 )
Just to make sure: no more bridge, src wlan1, forwarding - dst to ether1? What mode we use - station?
“Bridge” has many meanings in MT.
"“Wifi AP-bridge and station-bridge” mode = wifi 4-address mode
Setup 1
Having a “bridge” interface in the mAP Lite , and having wlan1 and ether1 as ports on that bridge, and using 4-address mode gives one L2 network for WLAN1 and ether1, aka one bridged/switched network where all devices connect without routing if in the same IP subnet.
Setup 2
Having wlan1 or ether1 disconnected from bridge interface (or just no bridge interface defined) gives L3 routed network. The IP subnet on WLAN1 and on ether1 are then different.
Local devices on ether1 use the mAP Lite ether1 IP as router/gateway.
WLAN1 has an IP address in the IP range of the AP.
3-address mode wifi is OK for this setup.
Access to the AP and to internet and other devices via WLAN1 is done with src-NAT/masquerade NAT FW rule, using the WLAN1 IP address only as src-IP.
Setup 3
Station Pseudobridge tries to imitate the setup 1, with only the setup 2 style 3-address mode wifi connection.
That imitation comes with limitations.
See also: http://forum.mikrotik.com/t/map-lite-in-repeater-mode/102580/1
Thank you, bpwl! The first setup worked immediately.
Will try the second at chance.
Great help, appreciated!
So, setup 2: (I will need some more help, because so fat did not manage to have it working):
Local Device on ether1 IP :192.168.36.13 port 502
0 interface=wlan1 mac-address=70:4F:57:03:13:03 ap=yes wds=no bridge=no rx-rate=“130Mbps-20MHz/2S” tx-rate=“65Mbps-20MHz/1S” packets=25293,25451
bytes=20920441,2142348 frames=25293,25471 frame-bytes=20971023,1992644 hw-frames=36803,25475 hw-frame-bytes=32705429,3113944 tx-frames-timed-out=0 uptime=16m10s
last-activity=0ms signal-strength=-47dBm@1Mbps signal-to-noise=70dB signal-strength-ch0=-51dBm signal-strength-ch1=-51dBm
strength-at-rates=-47dBm@1Mbps 0ms,-32dBm@HT20-7 59s350ms tx-ccq=59% p-throughput=38374 distance=1 last-ip=192.168.1.11 802.1x-port-enabled=yes
authentication-type=wpa2-psk encryption=aes-ccm group-encryption=tkip management-protection=no wmm-enabled=yes
log print:
add authentication-types=wpa-psk,wpa2-psk eap-methods=“” group-ciphers=tkip,aes-ccm mode=dynamic-keys name=profile1 supplicant-identity=“” wpa2-pre-shared-key=password
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=no_country_set disabled=no frequency=2462 frequency-mode=superchannel scan-list=2462 security-profile=
profile1 ssid=CXNK00765F8D station-roaming=enabled wireless-protocol=802.11
/ip hotspot profile
set discovery-interfaces=*4 interfaces=wlan1
add address=192.168.36.15/24 interface=ether1 network=192.168.36.0
add address=192.168.1.11/24 interface=wlan1 network=192.168.1.0
add action=masquerade chain=srcnat dst-address=192.168.36.13 out-interface=ether1 protocol=tcp src-address=192.168.1.11
add action=dst-nat chain=dstnat dst-address=192.168.36.13 dst-port=502 in-interface=wlan1 protocol=tcp src-address=192.168.1.11 to-addresses=192.168.36.13 to-ports=
502
add distance=1 gateway=192.168.1.1
add distance=1 dst-address=192.168.0.213/32 gateway=192.168.1.1
[admin@MikroTik] >
This is the relevant part …
add action=masquerade chain=srcnat out-interface=wlan1 protocol=tcp src-address=192.168.36.0/24
502
src-nat or masquerade
Local device 192.168.36.13 on ether1 will use 192.168.36.15 as gateway, and reach 192..168.0.213 via wlan1, identifying itself (masqeraded) to that device as source with IP 192.168.1.11
The answer packets in that connection will come back to 192.168.0.213 via 192.168.1.11 because that router will still remember that initial session as “established” and NATed.
dst-nat
Having 192.168.0.213 initiating a connection to 192.168.36.16 port 502 will need an extra FW dst-nat rule in the router.
192.168.0.213 will connect to 182.168.1.1 port 502 who will forward that to 192.168.32.16 port 502 , identifying itself as 192.168.0.213. “forward” because of the extra dst-nat FW rule
Now lets look again to the config (not tested, can be incomplete or contain typo’s)
add action=masquerade chain=srcnat dst-address=192.168.0.213 out-interface=wlan1 protocol=tcp src-address=192.168.36.16
#or more general#
#incoming request from wlan1 side requires#
add action=dst-nat chain=dstnat dst-address=192.168.1.1 dst-port=502 in-interface=wlan1 protocol=tcp src-address=192.168.0.213 to-addresses=192.168.36.16 to-ports=502
# following line is redundant on the above
If default FW rules are active blocking all incoming connections from WAN, and WLAN1 is still added to the WAN interface list … then a special “accept” rule needs to be added in the FW
Something like (can be more specifc from what interface, from what SRC address, … etc etc)
add action=accept chain=forward comment="allow forward port 502" dst-port=502 protocol=tcp
Why 192.168.36.16? Shouldn’t be 192.168.36.13 - the local device? And, the local device has its own gateway 192.168.36.120 setup, does that mean 192.168.36.15 will work like gateway for connection to 192.168.1.11?
Yes yes, correct. 192.168.36.13 if you take the same device for dst-nat as for the masquerade. (What is a very logical choice)
If have no clear diagram of the whole network setup in my head, and jumping from case to case in this forum, I don’t reread the full story every time, and sometimes addresses get mixed up.
Any of the 192.168.36.0/24 adresses can be used in outgoing or incoming connections, which are independent sessions when initiated from ether1 or from the wlan1 side.
For multiple client devices for incoming connections, then different ports, or different IP addresses are used with 192.168.1.0/24 to differentiate the devices.
For outgoing connections from ether1, src-nat (with different IP addresses) or masquerade (with the WLAN1 IP address) can be used (the outgoing TCP port is randomised with masquerade, so the TCP port number is the differentiator)
192.168.36.15 and 192.168.1.11 is the same device (router/gateway)
That router has 192.168.1.1 as its gateway for going to the rest (e.g. internet) of the IP networks.
192.168.36.15 will normaly be the gateway address for all the devices on ether1 (network 192.168.36.0/24)
Your other gateway 192.68.36.120 is also possible, and might point to gateway 192.168.36.15 for anything that is in that direction (e.g.over wlan1)
Stuck badly. No progress done.
Once again the topology I have, just to make sure I present it properly:
PC connect to wifi network - MT (Lite or MAP 2nd) - ethernet cable - Ethernet device (PLC with Ethernet port, no need of Internet)
In essence, I try to connect to the PLC without having connected the PC to it, but via MT.
For this last setup: one dedicated device using the MT as “wifi adapter”, the “station-pseudobridge-clone” mode is the most logical to use.
Maybe you had this earlier in a working condition, but are using a different device now (so there is a different MAC address to be set as clone, or none must be set)
“station-pseudobridge-clone” - similar to the station-pseudobridge, but the station will clone MAC address of a particular device (set in the station-bridge-clone-mac property), i.e. it will change itsown address to the one of a different device. In case no address is set in the station-bridge-clone-mac property, the station postpones connecting to an AP until some packet, with the source MAC address different from any of the router itself, needs to be transmitted over that interface. It then connects to an AP with the MAC address of the device that have sent that packet
More found here: http://forum.mikrotik.com/t/station-pseudobridge-in-3-x/21267/1
I ended up with this configuration, which of course does not work:
model = RBmAP2nD
serial number = DE4F0FF1A15E
add name=bridge1
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik wpa2-pre-shared-key=password
add authentication-types=wpa2-psk mode=dynamic-keys name=WDS
supplicant-identity="" wpa-pre-shared-key=password
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=
station-pseudobridge-clone scan-list=2412 security-profile=WDS ssid=
CXNK00765F8D tx-power-mode=all-rates-fixed wds-default-bridge=bridge1
wds-mode=dynamic wireless-protocol=802.11
/interface wireless wds
add disabled=no master-interface=wlan1 name=wds1 wds-address=DC:2C:6E:E2:FC:03
/interface wireless nstreme
set wlan1 enable-polling=no framer-policy=best-fit
/ip hotspot profile
add bridge=bridge1 interface=ether2 trusted=yes
add bridge=bridge1 interface=wds1 trusted=yes
/interface bridge port-controller
no hw support
set bridge=bridge1 cascade-ports=ether1 switch=switch1
add address=192.168.36.15/24 interface=bridge1 network=192.168.36.0
add action=accept chain=forward dst-address=192.168.36.13 dst-port=502
protocol=tcp
add distance=1 gateway=192.168.36.120
add distance=1 gateway=192.168.0.120
/system identity
set name=RouterOS
[admin@RouterOS] >
Any idea why it does not work or how to be adjusted?
Wow … adding a lot of unrelated complexity.
Pseudo-bridge you want (transparent wifi access to a non-MT AP) ?
Then don’t bother about WDS or “Controller Bridge and Port Extender”
I’ll try to clean up. IP addresses are only for IP access to the MT mAP and for the mAP own outgoing traffic.
Your connected device doesn’t use that IP information, goes straight through to the AP. The mAP acts as a bridge (pseudo bridge).
The IP network is between the AP and the client device only.
# model = RBmAP2nD
# serial number = DE4F0FF1A15E
add name=bridge1
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
add authentication-types=wpa2-psk mode=dynamic-keys name=WDS \
supplicant-identity="" wpa-pre-shared-key=password \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=\
station-pseudobridge-clone security-profile=WDS ssid=\
CXNK00765F8D tx-power-mode=all-rates-fixed  wireless-protocol=802.11
# following info only used by mAP
/system identity
set name=RouterOS
With this setup wlan1 does not run. WIFI SSID CXNK00765F8D cannot be even found during the scan, perhaps the reason is the mode “station pseudobridge clone”?
/log print
17:08:41 system,info router rebooted
17:08:42 bridge,info “bridge1” mac address changed to DC:2C:6E:E2:FC:00
17:08:43 bridge,info hardware offloading activated on bridge “bridge1” ports: ether1,ether2
17:08:44 interface,info ether1 link up (speed 100M, full duplex)
17:08:44 interface,info ether2 link up (speed 100M, full duplex)
17:08:51 system,info,account user admin logged in from 38:EA:A7:F5:8C:FD via winbox
17:08:53 system,info,account user admin logged in via local
17:09:19 system,info,account user admin logged in via local
17:12:22 system,info,account user admin logged out via local
17:12:28 system,info,account user admin logged in via local
17:12:31 system,info wireless security profile changed by admin
17:12:32 system,info device changed by admin
17:12:32 system,info route added by admin
17:12:32 system,info system identity changed by admin
17:14:11 bridge,info “bridge1” mac address changed to DC:2C:6E:E2:FC:00
17:14:11 system,info device changed by admin
17:14:11 bridge,info hardware offloading activated on bridge “bridge1” ports: ether1,ether2
17:15:02 system,info,account user admin logged out via local
17:15:20 system,info wireless security profile changed by admin
17:15:57 system,info,account user admin logged out via local
Further, I am pretty sure that the PLC port must be used somewhere in the setup. Don’t you think so? If yes, where?
When I connect the PC to the PLC directly, the OPC UA server I use to communicate with the PLC requires IP address and port number. The connection is instant, no issues.
Changing to Station Pseudobridge makes wlan1 working. But still no connection to the PLC.
admin@RouterOS] > /interface wireless registration print stats
0 interface=wlan1 mac-address=48:77:46:85:6B:9A ap=yes wds=no bridge=no rx-rate=“117Mbps-20MHz/2S”
tx-rate=“104Mbps-20MHz/2S” packets=17538,9252 bytes=8862784,830241 frames=17538,18106
frame-bytes=8897856,1460954 hw-frames=37900,18694 hw-frame-bytes=17084397,2231026
tx-frames-timed-out=0 uptime=19m40s last-activity=0ms signal-strength=-61dBm@1Mbps
signal-to-noise=52dB signal-strength-ch0=-62dBm signal-strength-ch1=-69dBm
strength-at-rates=-61dBm@1Mbps 0ms,-58dBm@HT20-4 10m57s160ms,-63dBm@HT20-6 5m57s90ms,-58dBm@HT20-7
15m57s380ms
tx-ccq=73% p-throughput=69066 distance=1 last-ip=192.168.1.7 802.1x-port-enabled=yes
authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm management-protection=no
wmm-enabled=yes tx-rate-set=“CCK:1-11 OFDM:6-54 BW:1x SGI:1x HT:0-15”
[admin@RouterOS] >
So why was it in the config then ? I have no idea and don’t have any saying on what your SSID look like. I only left it in the config because it was in yours.
last-ip=192.168.1.7
Where does this come from??? AP and PLC need an IP in the same subnet! With a bridge or pseudo-bridge one does not route between subnets. It’s all one and the same subnet.
https://forum.mikrotik.com/viewtopic.php?p=982248#p980835 was the router exemple, with different subnets. This was not a L2 one subnet bridged exemple.
Don’t mix the requirements for routed with optional NAT or masquerade on the one hand. https://forum.mikrotik.com/viewtopic.php?p=982248#p980835
And just non-routed direct bridged and same subnet on the other hand. https://forum.mikrotik.com/viewtopic.php?p=982248#p982106
