hello,
iam new with mikrotik and i need to understand the mikrotik concept by showing me step by step wan load balancing as well as failover with explanation,
thanks
hello,
thanks
I’ve followed these ones to play with loadbalancing :
http://mum.mikrotik.com/presentations/US12/steve.pdf
http://mum.mikrotik.com/presentations/US12/tomas.pdf
There are a lot of docs on the net…
this looks like what i am looking for…many thanks…
Many thanks..this looks like a great help…if i have any questions on this document, is it possible to ask you ?..thanks
somehow i have difficulty understanding this lines under the tomas.pdf
addchain=prerouting connection-mark=WAN1->LANssrc-address-list=LAN action=mark-routing new-routing-mark=ISP1_Route
addchain=prerouting connection-mark=WAN2->LANssrc-address-list=LAN action=mark-routing new-routing-mark=ISP2_Route
=it is talking about the wan2lan but why it uses src address ans LAN
Glad to know you’ve found it helpful.
I’m learning too so probably I’m not the right person to ask for detailed explanations, however , those lines are used to manage a connection coming from WAN to be answered out on the same WAN
First the incoming connection from a specific WAN with no marks is marked as WANx->LANs
Then the packets flowing out from LAN (address list=LAN) , with WANx->LANs mark are further “routing-marked” as ISPx_Route to be associated to relative ISP route into the IP routing table: look at previous page with :
add gateway=1.1.1.1 routing-mark=ISP1_Route distance=1
I hope this is clear (and not a mistake…)
the way it was, confuses me…why dont we just use the established option.
