Hi to all members,
I have some strange problem with skype behind nat on routerboard 751U. When start a video call from skype everything is perfect for a while (20-30 sec.) then on my side I can’t see other side and can’t hear them, at the same time they see me and hear me perfectly.
Routerboard is brand new, regular setup from quick setup (AP or home AP, I use it at home) a few ports forwarded to internal machines and … thats it all. I tried to start and stop UPNP - no difference. To see if the problem is mikrotik, I turned on my old router (pfsense) and with it, everything worked smoothly.
/export compact
# jan/02/1970 07:13:43 by RouterOS 5.25
# software id = PB83-XS6P
add admin-mac=DXXXXXXXX7 auto-mac=no l2mtu=1598 name=bridge-local protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-below country=bulgaria disabled=no distance=indoors frequency=2467 ht-rxchains=0,1 ht-txchains=\
0,1 hw-retries=4 l2mtu=2290 mode=ap-bridge ssid=t-net-h wireless-protocol=802.11
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=passthrough mode=dynamic-keys supplicant-identity=MikroTik \
wpa-pre-shared-key=XXXXXXXXXXX wpa2-pre-shared-key=XXXXXXXXXXX
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp ranges=192.168.114.100-192.168.114.160
add address-pool=dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.114.254/24 comment="default configuration" interface=wlan1
add address=10.81.51.114/16 interface=ether1-gateway
/ip arp
add address=192.168.114.57 interface=bridge-local mac-address=XXXXXXXXXXX
/ip dhcp-client
add comment="default configuration" interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.114.51 client-id=XXXXXXXXXXX mac-address=XXXXXXXXXXX server=default
add address=192.168.114.52 mac-address=XXXXXXXXXXX server=default
add address=192.168.114.53 client-id=XXXXXXXXXXX mac-address=XXXXXXXXXXX server=default
add address=192.168.114.49 client-id=XXXXXXXXXXX comment="Nexus 7 Nikola" mac-address=XXXXXXXXXXXserver=default
add address=192.168.114.54 client-id=1XXXXXXXXXXX comment=S3-tolostoi mac-address=5XXXXXXXXXXX server=default
add address=192.168.114.50 mac-address=XXXXXXXXXXX server=default
add address=192.168.114.57 comment=server mac-address=XXXXXXXXXXX
add address=192.168.114.0/24 comment="my configuration" dns-server=192.168.114.254,10.81.0.1 gateway=192.168.114.254 netmask=24
set allow-remote-requests=yes servers=10.81.0.1
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=input dst-port=10001 in-interface=ether1-gateway protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=80
add action=dst-nat chain=dstnat dst-port=20 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=20
add action=dst-nat chain=dstnat dst-port=21 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=21
add action=dst-nat chain=dstnat dst-port=15000-15100 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=15000-15100
add action=dst-nat chain=dstnat dst-port=122 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=22
add action=dst-nat chain=dstnat dst-port=322 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.52 to-ports=22
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=443
add action=dst-nat chain=dstnat dst-port=143 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=143
add action=dst-nat chain=dstnat dst-port=25 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=25
add action=dst-nat chain=dstnat dst-port=587 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=587
add action=dst-nat chain=dstnat dst-port=110 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=110
add action=dst-nat chain=dstnat dst-port=993 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=993
add action=dst-nat chain=dstnat dst-port=995 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.114.57 to-ports=995
add action=dst-nat chain=dstnat disabled=yes dst-port=80 protocol=tcp to-addresses=192.168.114.57 to-ports=80
/ip neighbor discovery
set ether1-gateway disabled=yes
set wlan1 disabled=yes
add distance=1 gateway=10.81.0.1
/ip service
set ftp disabled=yes
set www port=10001
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=ether1-gateway type=external
/system clock
set time-zone-name=Europe/Sofia
/system identity
set name=tstoi-R51
/system leds
set 0 interface=wlan1
/tool graphing interface
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
/tool traffic-monitor
add interface=ether1-gateway name=tmon1 threshold=0
If need some more information - just ask.
Thanks in advance!
