Strange bug when tryeing WiFi ACL
Hello!
I've using C52iG-5HaxD2HaxD (7.23). I have tried to use WiFi 5GHz AX Access List to put some device in the particular VLAN. It seems to be working solution. And almost it has been done, besides dns. I'm used my smartphone for tests. But, when a decide to take a brake and disable ACL rule... My phone stoped to see wifi network I used. It see 2.4 AX wifi from same router. Second phone and 2 laptops can connect to 5GHz wifi but not the phone I user in ACL.
Both, router and phone, were rebooted. Router updated from 7.22.? to 7.23. Tried to remove rule and set only accept without VLAN mentioning... Nothing. One phone unable to see this wifi network anymore.
Maybe some one know, what can I do with this?
Welcome!
Could it be that you're using Winbox 3?
No, I'm using version 4.1. But Linux version. Is this matter?
And... Network is visible again with no cause! And I can't figure out what I do for this. Changing some frequency setting, indor parameter set up, trying to delete whole wifi interface and can't becose of error... After every move I'm checked out network visibility with no success... And then, accidentally I have looking in network list and saw my lost network! Magic!
I'm loving mikrotik devices, but many of such stories in my practice with despaire attempts to avoid another bug in them... It make me disappointed.
Its your setting over there..... next to that other config..... left ...no left.... no up ....that one!
how about post your config, instead of complaining the product isn't working how you would like, like a dumb user who only joined the forum 3 hours ago ?
Saying the product is making you disappointed cause you don't know how to use it is lame too.
All said. For sure a Mikrotik "bug" :rofl:
Very "funny". Config you have needed? Which part? VLAN? WiFi? What parameter can make wifi network invisible for one particular device and seems normal to other? I hope than some one here have an idea about this. But I see, this forum for jokers.
Yes, it's needed. Your ask for help seems to be kind of:
"I have a car with modified suspension, modified engine, modified ignition map and I have a problem connecting a customized trailer to it but some other trailers I could attach however using different hook. Can you help me?"
Is it a problem with a truck or typical passenger car?
@abera86, with all due respect, I welcomed you and directed you to the guidelines. Unfortunately, we cannot know the details of your device setup, so we need to see your configuration in order to help. I'm glad to hear you were able to resolve the issue yourself by exploring the settings. Since the issue was resolved that way, it does not appear to have been a bug.
Yes, similar symptoms can be caused by a bug in WinBox 3.
Okey, jokers! Thanks for your patience and great kindness)
I have figure out for reason of this "bug". You are right, problem need to be analyzed with cold head and proper facts. I've been confuzed with future which is new for me but problem was in area which I have not expect. I'm try to reproduce yesterday pracrice. All working. I'm open documentation and try to read about ACL in WiFi. Found how to get regional frequencies parameter example: /interface/wifi/radio/reg-info country=Latvia 0 .
Then try set diapason with bigger power: 5490-5730, - and network disappeared. For example on 5500/ax/Ceee. Smartphone realme 10. Secondary older phone - can see it. Laptops with 2020 and 2024 years of manufacture too. But not realme 10. I have 3 country specific diapasones:
ranges: 2402-2482/20dBm/40MHz - not in case
5170-5250/23dBm/160MHz - good
5250-5330/23dBm/160MHz - good
5490-5730/30dBm/160MHz - problem
5735-5835/30dBm/80MHz - good
I don't know, maybe some malfunction in my device only. Or in this model. Or in firmware. Or maybe regional parameters different in phone firmware and router os...
Sorry for terrible English. Glad that my efforts give me something.
Maybe your Realme 10 just does not allow UNII-2c bands?
