strange problem importing rsc script
Hi all,
I have been designing a simple program that generates a script file to be imported in to a fully reset (i.e. no defaults) Mikrotik router.
However when I try to import the rsc file generated by the program I get this error:
expected command name (line 1 column 1)
I don’t know why, when I copy the text of the RSC file and paste it into the terminal window it’s fine, but if I try and import it I get the error.
Here are the first few lines of text in the rsc:
:log info "**** Starting auto-setup script ****"
:log info "Configuring log to file..."
/system logging
	action add target=disk name=ScriptLog disk-file-name=ScriptLog disk-file-count=1
	add action=ScriptLog topics=script
:log info "Creating bridge interface..."
add arp=proxy-arp name=bridge-LAN
It throws the error on the first Char!
Here is the output of an import verbose=yes command:
#line 1
▒▒▒:log info "**** Starting auto-setup script ****"
What are those characters before :log?
Any help gratefully appreciated.
tslytsly
They could be spaces, tabs or other nonvisible characters as “hardspace” or … you have edited and copied script as UTF-8 file and then strange chars come from UTF coding.
My advice: Copy scripts from Winbox to “stupid” NotePad and then look for nonstandard characters. Remove them and copy the script back .
Hmm, I think you’re right, when I paste that character into an online UTF decoder it shows as “medium shade”.
I’ll see if I can make my program output ascii.
thanks
tslytsly
That was it!
I never even considered the text encoding, it seems vb.net uses UTF-8 by default.
I just had to force it to write the script using ASCII.
Thanks BartoszP
tslytsly
Notepad++ will/should be your friend :slight_smile:
Actually I already use it for everything.
I even have a custom style for RouterOS so rsc files look like the terminal.. :sunglasses:
in this case Notepad++ didn’t show the medium shade characters.
As it silently have recognized as UTF so the script had been displayed/saved directly as UTF.
Sometimes notepad is the best tool …
