Hi all,
I picked up a hAP ax3 router recently for my business; The reason I got it was that our ISP (the only one available in the building) has some specific configuration requirements that a more basic home router didn't have options for. It was a little tricky to set up, but I somehow got it working after poking around in the settings for a bit. Until a couple days ago, for some reason it randomly lost the connection completely, and I haven't been able to get it up and running again. I've been in touch with the ISP and there is no issue on their side, they said that they can detect the router so AFAIK the link up that point is stable. I'm pretty sure it's some kind of configuration issue, but a lot of the options in RouterOS are way over my head (not an IT pro). If someone can point me in the right direction I'd be incredibly grateful!
Here's what our ISP provided us with for configuration requirements:
xxx is handing off your network circuit as 100Mbps Full Duplex. Your network hardware must be configured as 100Mbps Full Duplex with auto-negotiation off to ensure maximum network throughput and stability.
Circuit ID: xxxx
CIDR: ELIDED.114/31
IP Address: ELIDED.115
Subnet Mask: 255.255.255.254
Gateway: ELIDED.114
DNS1: 66.28.0.61
DNS2: 207.126.96.248
Steps I've taken so far, based on what I understand the usual setup process to be:
-Did reset on the overall configuration, except users
-Reset the Wifi SSID/password to what I had before
-Added ...114/31 under IP/Adresses, with interface ether1 (where the fiber converter is plugged in). The "Gateway" field populated automatically to ...114.
-Turned off autonegotiation on ether1 and set to 100M full duplex. The link appears to be good, although it requires disabling and re-enabling the interface one time.
-Added a default route; I first added 0.0.0.0/0 -> ...114; However, the status showed "unreachable", and when I tried pinging 8.8.8.8, I got a "no route to host" message, so I tried changing the target to "%ether1" and that shows as active.
That's pretty much it so far; When I try a ping now it alternates between timeouts and "...114: host unreachable". Full configuration is below for reference. Apologies if I'm missing something glaringly obvious here - Definitely not my area of expertise! Thanks in advance for your help ![]()
# 2025-09-11 11:49:22 by RouterOS 7.19.6
# software id = **ELIDED**
# model = C53UiG+5HPaxD2HPaxD
# serial number = [redacted]
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] auto-negotiation=no speed=100M-baseT-full
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.mode=ap .ssid=**ELIDED** disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.mode=ap .ssid=**ELIDED** disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=...114/31 interface=ether1 network=...114
/ip dhcp-client
add comment=defconf default-route-tables=main interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=66.28.0.61,207.126.96.248
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether1 routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
"\r\
\n :foreach iface in=[/interface/wifi find where (configuration.mode=\"ap\" && disabled=no)] do={\r\
\n /interface/wifi wps-push-button \$iface;}\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
