Suggestion for a MikroTik device for field Wi-Fi speed and quality testing
I would like to share a product suggestion that we believe has strong potential for use by field technicians, Internet service providers, and technical support teams.
The idea is a compact and portable MikroTik device, with an integrated display, designed specifically for quick on-site testing of internet speed and Wi-Fi signal quality, without the need for a laptop or smartphone.
Suggested key features:
  • Measurement of download and upload speeds (speed test)
  • Display of latency (ping) and jitter
  • Evaluation of Wi-Fi signal strength and quality (RSSI, SNR, interference)
  • Support for 2.4 GHz and 5 GHz bands
  • Simple and intuitive interface, ideal for fast field use
  • Standalone operation
  • Power via USB or internal rechargeable battery
Benefits for field technicians:
  • Faster validation of delivered bandwidth
  • Easier diagnosis of Wi-Fi issues at the customer’s location
  • Visual tool to demonstrate results to the end customer
  • Reduced rework and increased efficiency during installations and support visits
We believe a device with this focus would fit perfectly into the MikroTik ecosystem, adding value for ISPs, integrators, and technical teams.
We would be happy to further explain the idea and share real-world field experience if needed.
How do you want to enter WiFi credentials on that screen?
Aren't the Android & iOS based zylions of WiFi testers easier to use?
Already exists, all you need is a smartphone.
Yes, and you don't need to type in the wifi ssid and password if you have a QR code to your device.
Well, the suggested design is interesting, it has also three RJ45 ports, marked LAN, WAN and DC :astonished_face: [1], besides a DC jack.
The USB port(s) - if any - must be on one of the not shown sides.
Now, it could become the best travel router ever made doubling as network test tool.
It would be nice adding a bluetooth interface so that - optionally - one could use a bluetooth external keyboard.
Now, fitting all that and a (I presume) 2.8" or 3.4" touch screen in a small case, passive cooled might be a little tricky from an engineering point of view.
As a pure "measuring wi-fi speed" device it would have very little use, but if the design is for a new (completely hypothetical)"mAP n" it would, I think, sell like hot cakes, even at a premium price, and if possible, could even evolve in a "LTE map n", if a 5G/LTE modem is added.
[1] this could be a passive 12-57V and PoE, PoE+, PoE++, PoE ++ (or 802.3af/at/bt) tester with checks for both Mode A and Mode B and for 4 pair mode.
As a bonus it could - connecting one end of a cable to this port and the other one to the LAN port, double as cable integrity tester.
Why not take a look at Darren Kitchen, Hak5 Founder device, but it was design for hacking.
https://hak5.org/collections/home1/products/pager
It's a Linux device so it can't be so difficult to add like iperf3 to it.
Or Speedtest by ookla, sadly this what i understand not FOSS, so maybe this is not compatible to mips.
