EDIT: Enabling strong-crypto for ssh sets these, I managed to miss this in my testing! Leaving this here for people arriving by Google.
I discovered today that I could not SSH to any of my routers as a result of our new corporate security policy.
The only MACs (Message Authentication Code, for other readers) that appear to be currently supported by the RouterOS SSH server are: hmac-sha1,hmac-md5
Our corporate policy only allows stronger MACs such as hmac-sha2-256 or hmac-sha2-512. (Ideally we would like to be able to disable the other MACs, specifically hmac-md5, but that is not crucial here)
Would it be possible to enable support for these MACs in a future RouterOS release?
But it doesn’t seem to work on RouterOS v6 (tested with v6.49.. Enabled strong-crypto but I still can’t connect without re-enabling SHA1 (disabled by default on CentOS 9): https://serverfault.com/a/1095899/132219. I get:
ssh -o MACs=hmac-sha2-256 user@MikroTik system identity print
Unable to negotiate with MikroTik port 22: no matching MAC found. Their offer: hmac-sha1,hmac-md5
Unfortunately Mikrotik’s documentation doesn’t include history … e.g. which ROS version brought certain feature or change in behaviour. So mostly it conforms to latest ROS version (e.g. 7.16) except when it doesn’t (e.g. when they forget to update docs). General rule of thumb is that wiki pages (being abandoned) are about v6 and help pages are about v7.
As to ssh: OpenSSH (and distribution maintainers) deprecated many older key exchange algorithms snd cyphering algorithms … many of those are considered “state of art” in ROS (yes, SSH implementation in ROS has falklen pretty much behind mainstream). So wgen using modern linux (or other) SSH client, one has to enable a few deprecated algorithms to allow connection to even latest ROS.
Regarding your ROS version: you may need to update to latest 6.49 … 6.49.17 is latest stable, it might make a difference.
Just faced the same problem.
Seems like negotiation is broken on 6.49.8 Long-Therm and that’s why:
On normal condition OpenSSH client says Their offer: hmac-sha1,hmac-md5 and it won’t connect at all nowadays.
First, I enabled strong-crypto: yes on server-side but nothing changed.
Second, I’ve decided to pin hmac-sha1 on client-side just to establish connection at least and then it reported Their offer: hmac-sha2-256 O_o
So finally I’ve pinned hmac-sha2-256 on particular host in my OpenSSH config and voila we're happy now.
