Sxt lte cat6 vs sxt lte cat7
i had the sxtr lte with the cat6 modem, and support for B20 (800mhz) was very bad because of almost non existent antenna gain (around 1dBi). the new cat7 sxt supports B28 (700mhz), and i can't find any antenna gain graphs - did mikrotik upgrade the antennas or used the same one? if they used the same ones, then on 700mhz the antenna gain will be even worse, going to negative gain.
any info?
most of our local masts now have B28 + B20. not sure if cat7 modem supports aggregation between those 2 bands?
tnx
@normis do you have any info? tnx
Let me teach you a trick:
if you want some answers and want to clear up your doubts, try reading...
the product documentation!!!
Yes, it’s a pretty handy trick! You should give it a try...
Read this
or this
(I’ll let you in on a secret: both are on the product page! Just scroll down!)
And... negative gain?... N/C
The antennas are the same, it seems.
