I’m having problems with 3 SXT-LTE units. One goes through its boot cycle and at the end of it LAN 1 green light goes out and there is no connectivity, my laptop saying cable disconnected, if i plug in a network lead into LAN 2 the green light on LAN 2 comes on and the laptop says cable is connected but i don’t know what the ip of LAN 2 is.
Second one fails login with bad user name or password.
Third one fails to login with bad user name or password.
My problem is what ever i do i cant reset to factory defaults, holding the reset button when powering up doesn’t work. If i use netinstall the second and third unit are recognized but when i press install it changes from ready to installing but after 20 seconds returns back to ready and hasn’t re-flashed the units.
I’ve worked on Cisco down to Netgear and find these units brilliant when they work but flaky when they don’t.
SXT-LTE have 1xEthernet with working at 3 or 7 band only, you probably say about new SXTR with some lte module KIT.
Upgrade WinBox.
