Device and software:
Device: MikroTik SXTR
LTE modem: R11l-LTE7
LTE modem firmware: R11l-LTE7_V005
RouterOS versions tested:
7.23.1 stable
7.24rc1 testing
Operator: T-Mobile CZ
LTE mode only
APN: internet.t-mobile.cz
Roaming disabled
When CA is used, the LTE link randomly stops working. In RouterOS logs it appears as
lte1 link down
and then
lte1 forced reconfiguration due to difficulty setting link up
After adding a diagnostic script, I found that during the failure the modem reports:
AT+CFUN? → +CFUN: 4
Sometimes also *RADIOPOWER: 0
AT+CPIN? → +CPIN: READY
AT+COPS? → +CME ERROR: no network service
AT+CEREG? → usually +CEREG: ...,0
AT+CGATT? → +CGATT: 0
AT+CEER → +CEER: "0 Unknown"
The issue happens even with strong signal and stable cell information.
When using automatic bands or B3+B7 or B20+B1, the issue continued.
After locking to B3 or B1 only, the router had approximately 14 days+ uptime without the issue.
Any ideas? Thank you.
I have a similar issue as well, but my connection drops every 16-23 hours, I don't have logs saved yet but my ping spikes to 6k+ and the speed drops to basically nothing for 3 minutes, then it fixes itself.
My device and software:
Device: MikroTik wap ax lte7
Operator: MT:S Serbia
LTE mode only
APN: gprswap
Roaming disabled
I'm on B3@20mhz+B1@10mhz, same thing happens on automatic band selection.
gitare3
September 28, 2026, 10:07am
3
Seems to be fixed with the new modem version R11l-LTE7_V006 .
martyy
November 10, 2026, 3:25pm
4
Hello there,
I have faced a very similar issue, but the modem upgrade to R11l-LTE7_V006 did not help.
Over time, can you please confirm whether the new firmware alone resolved your issue?
Thank you!
Setup
Device: RBSXTR (SXT LTE7 kit, board SXTR r3), modem R11l-LTE7
RouterOS 7.25.1, RouterBOOT 7.25.1 (also seen on 7.24.2 / RouterBOOT 7.20.6)
Modem firmware: R11l-LTE7_V006 (also seen on V005)
Operator: Vodafone CZ (PLMN 23003), APN "internet", home network, LTE data only. No other
device on this SIM.
Fixed outdoor installation, not moving. Power over PoE-in. The router supplies PoE-out to
one device on ether2.
Radio conditions
The serving cell is excellent the whole time:
Cell: TAC 0x797c (LAC 31100), ECI 0x0012040b (eNB 4612, sector 11), PCI 431, B20, EARFCN
6400, 10 MHz
RSSI -47 dBm, RSRP -69 dBm, RSRQ -7.5 to -9.5 dB, SINR 16 to 33 dB, CQI 12 to 15
The only neighbour in /interface lte cell-monitor while connected: PCI 430, B20, EARFCN
6400
Problem
Every 15 to 40 minutes the modem drops registration on the good cell (+CEREG: 0, not
registered). It then repeatedly camps on two other cells:
TAC 0x3852, ECI 0x0669690b, PCI 213 (0x0d5)
TAC 0x05f3, ECI 0x06696900, PCI 126 (0x07e)
The modem reports +CEREG: 11 on both, and +CEREG: 3 (registration denied) on the 3852 cell.
I can provide detailed AT command logs from the critical moments.
gitare3
November 10, 2026, 10:02pm
5
Since firmware R11l-LTE7_V006 it's much better, but not perfect.
In auto band selection mode, there were still some drops, but maybe after 2-3 days. It was mostly selecting B3+B7.
Since locking to B3+B20, I have e.g. now session uptime 15 days.
With this combination I have lower speeds, but much better stability.
