Greetings,
Tried to search for similar case in forum, but failed to receive usefull hints.
Just got pair of fresh SXTsq 5 ac and using following conditions, got perfect Bandwidth test using between devices, upd/tcp up to 866Mbit both directions:
distance 50m outside
played with Txpower and best figure is 8 on both antennas
Strength -53/-53 dBm
CCQ jumping close to 100%
5Mhz AC only + 20/40/80 Ceee of course
nstream or nv2 are much slower, so stopped on 802.11ac
But … is file transfer is awfully slow ~40Mbits. Tests were performed in different conditions, even trying to make setup in garage at 20m distance.
PS. LV/RUS/EN answers are welcome
Hello, i use internal Mikrotik BTest tool direclty in devices via Winbox, as well as on Windows.
Connection A: 1st PC windows 10 (BTest) → 1st antenna SXTsq 5 ac → 2nd antenna SXTsq 5 ac → 2nd PC windows 10 (BTest) shows 700Mbits
Connection B: 1st antenna SXTsq 5 ac (BTest) → 2nd antenna SXTsq 5 ac (BTest) shows 800Mbits
But file transfer between PCs in Connection A is very poor, like i mentioned in post about ~40Mbits
Distance 20m Outdoor, free Channel (checkt with Spectrum in Ligowave), 20 MHz
Mikrotik Modulates @173 MBit
Real TCP throughput in send or receive Direktion is 75-80 MBit, Nv2 is under 50 MBit, nstreame does not work, no connection possible
ROS 6.42 rc 39
I swap the SXT against Ligowave DLB5-20ac
With ipoll3 Protocol we get constant 130MBit real TCP
Looks like we have to move, 50MBit more with one 20Mhz Channel
I will do some further tests and make some photos / screenshots
I will test mimosa too.
Reading before answer…
I Test from RB1200 to RB1100ah
If I test with direct cable they can do about 350MBit TCP, so there is no Limitation for this Test
