Awesome!
Awesome!
Thanks. This comes in very handy
Sent from my iPhone using Tapatalk
Is anyone interested in updating language definition for the most current version of RouterOS?
Yes Please, that would be great.
Gesendet von iPhone mit Tapatalk Pro
Sure…
Great! please keep up!
Just tried it… Sweet exactly what the doctor ordered…
Thanks!
This is an awesome package, much appreciated.
Is it possible to have line and block-comment keyboard shortcut support?
i.e. Pressing [Ctrl + /] or [Ctrl + Shift + /] will add '# ’ to any lines selected?
Very Much Appreciated.
Its my go to now for scripting. Thanks for the Mikrotik support. It’s so much easier with highlighting.
Great !!
Just found that MikrotikScript have disappeared from the available syntax options in my instance of Sublime Text
What is more interesting, is that after I add the MikrotikScript package, Sublime Text will forcefully delete it, and this occurs only within few seconds after launch…
Purchasing a license is not justified as I’m not a programmer, so I just installed a demo downloaded from sublime, used somewhat extensively for a short period before abandoning the editor.
Now, six to 12 months later since I last used Sublime, I’m seeing this behaviour. Can’t tell exactly when this editor started acting this way…
Has anyone seen this?
I have a licensed version of Sublime Text Version 3.0 Build 3143 and I have no issues with the MikrotikScript.sublime-package.
Call for contributors
I’m happy to review and accept Pull Requests with support for new keywords introduced by RouterOS.
Hello, @Kentzo
Here https://packagecontrol.io/packages/MikrotikScript the last version is 1.3.6 and same mentioned on github https://github.com/Kentzo/MikrotikScript/releases
But you’ve made changes later, on 30 Jan 2016 for example. The question is: if all of the last changes are in the compiled package?
'Cause, e.g. “:return” or “:typeof” keyword highlighting won’t work for me, but “:totime:typeof” - works - and that is, as far as I remember, one of the last fixes on github.
I’ve installed your highlight theme via package installer in Sublime 3. Maybe not all of the recent changes are in that package? If so - how do I compile the sources from github for Sublime Text? Or, what will be much better - maybe you will kindly agree to do that for us?
Pushed a new tag that includes all changes, should be propagated to PackageControl soon.
Thanks alot!
Thanks, this is great!
Now if only someone made the same for emacs… ![]()
woow very beautiful
