Syslog Notification execute on Server
Hello!
I try in Dude the action in the notification with “execute on server”
For example:
/ system script run script1
or
/ file print file = myFile
Actually I want to call telegram:
/ tool fetch url = "https: //api.telegram.org/bot
All scripts work with the “Test” button but with one
Syslog Rule will not run the script. I have added an extra 2nd rule and set the first rule that writes to the syslog “passthrough”.
Another attempt: just a rule that just gets the “execute on server” notification.
The script is never executed, only with the testbutton.
What’s going on there?
Does somebody has any idea?
Best regards
Uwe
“execute on server” it works on status change but not on syslog notification
I use version 6.41.3
can someone explain that?
Hi, I have the same problem, did you solve it?
You have to put the notification within a group.
http://forum.mikrotik.com/t/syslog-server-notification-using-execute-on-server/52558/1
