I want to run a PHP file when somone connects to MikroTik HotSpot. So I configure The Dude v4b3 and MikroTik. I can see the result in The Dude Syslog but when I configure new notification with the command below and the “execute locally” type, although the Test button is working o.k. but the real log is not working (my PHP file is not executed):
What is wrong here?
don’t enter a path there. only the “exe” name. this “exe” must be in a windows registered path.
to test if it will run, enter it’s name in your windows “RUN” dialog. if it doesn’t work there, it will not be executed in Dude
try to put the file next to php exe and don’t use path for it, or quotes. experiment with different ways
as you know, Dude has not seen updates for years, and crashing in certain situations is a known bug. there is nothing I can do. we are still planning a Dude 5 with a complete rewrite, so hope is not lost
