System Backup
I am trying to setup an automatic backup on a router running 4.17 and none of the examples below work:
http://wiki.mikrotik.com/wiki/Scripts#System_Maintenance
Anyone else having issues? Something change from 3.x to 4.x?
I got mine working on ROS 4 & 5 using the third (3) example.
http://wiki.mikrotik.com/wiki/Send_Backup_email
I added JUST the script part… and then manually setup the Scheduler (On Event : backup)
This is not the exact same as File > Backup, it will export the config to a text readable file.
