I use a BaseBox 2 in WDS link with a QRT2.
Both run on routerOS 6.32.3 bugfix.
I configure a virtual AP on each routerboard on which roaming users are connected.
BaseBox2 is the Hotspot server (DHCP).
All goes right with setting. But today I have got a system error critical message “login failure for user…” as you can see on screenshot below :
someone can explain this ?
Did I need to be worried ?
Don’t know who is it !
I need telnet service because I have to use “MAC Telnet” for connecting relay Access Point (AP2) by WDS link…but can you tell me why I can’t use “Telnet” to connect AP2 ?
My Desktop is connected to AP1 behind standard router .
I can access AP1 without issues using WINBOX. But I must to use “MAC Telnet” for AP2 because “Telnet” can’t connect to routerboard.
