Hello. Am a student in electrical engineering and am trying to work on project. I want to design a network provider system for a specific area by using Starlink as the internet provider. During my research i discovered that i needed a mikrotik router to act as an interface that allows me to control which Devices are allowed to connect to the network. Any help on how i can do this project and what i will need to have it running would be appreciated.
We are not doing your homework
No.. i have worked out something.. but i would love some advise on how it can be done
What have you worked out?
Mikrotik would only be 1 of 100 devices/brands/boxes that can do this.
There are several solutions to this, 1 would be a simple firewall-rule in the "forward chain" that simply denies certain IP addresses of the devices that you want or do not want to give access.
Your use-case sounds very abstract to be honest, "network provider system for a certain area" ?! wtf does this even mean ? Area as in geographic location somewhere ?
The cheapest Mikrotik box can be used for your use-case (eg. anything like a hEx etc)
The idea with a student project is that you gather information from internet, like sales brochures, technical manuals, general information etc and that you design your system based on that.
Not ask on a forum "please help me with doing it". The most you can ask on a forum is where relevant information can be found.
Your are on a good way. Forget that there is a Starlink involved as it's just an external source of Internet, you can connect your router to any ISP.
Next step is to look for fours keywords "mikrotik voucher hotspot configuration" using your favourite search engine. It should give you many examples for your project's next step.
If you have worked something out, then put your ideas up here and ask for comments and review. Diagram and several paragraphs of explanation.
Doing that will get you feedback far more willingly than asking us to do your homework.
noted
