System - Shutdown query
What would happen if the MikroTik is turned off from system shutdown? How can I turn it on again if I don’t have physical access to it?
MT devices in shut down state stay in that state until they are power cycled.
How to work around it? If device has option to be powered via PoE, then you can power cycle it by disable PoE out on port of powering device. Or install some 3rd party remote-operated power switch. Or ask somebody local to do it.
Thanks for clearing up the doubt
If you plan to use a remotely operated power switch, make sure that with the router shut down that you will be able to access the power switch. It would not work well to use a remote power switch that is operating on the LAN from the router that is shut down…
My solution: HHT-NET2D Ethernet relay
More information (user manual, configuration software): Microchip Community Forum (search for the device)
