prompts me for a password, but rejects knowngooduser’s password (which works with the windows UI).
/system ssh [ip address of unix box] user=remoteusername
just hangs. After about 30 seconds, it returns with “Welcome back!”, which it also does in response to ctrl-C. I can see TCP packets flowing to port 22 on the other end up to the hang. I don’t see anything from sshd on the other end about those attempts.
The ssh server in the routerbox works just fine, including port forwarding, so I can sort of make do without for now, but it would be nice to have a functional ssh client.
I’m using 5.4. I’m really, really, really, really sure sshd on the target machines are working and reachable.
I can run tcpdump on the target machines and watch a whole lot of traffic going back and forth up to the point where it hangs, then times out.
The machines in question are macs running the latest Snow Leopard and a FreeBSD machine running 8.2-RELEASE. And, as I mentioned, I can’t even correctly connect to localhost with knowngooduser.
I found the steps to import a private key pair, and using the keypair works. But password authentication does not. I also, seemingly, cannot ssh to a dns name that is IPv6 only. I can, however, ssh to an IPv6 literal.
