ste
July 25, 2014, 10:08am
1
We use SFP Modules outdoor in Switches with extended temperature Range.
What is the temperature range for the Mikrotik SFPs?
SFP DDM:
Identifier SFP transceiver
Connector LC
SONET Compliance N/A
Ethernet Compliance 1000BASE-LX
Vendor Name Mikrotik
Vendor OUI 000000
Temperature 69.01 (°C)
Voltage 3.32 (V)
TX Power -5.40 (dBm)
normis
July 25, 2014, 10:20am
2
Officially all SFP modules have “Commercial operating temperature range:0°C to +70°C”, I am not sure about real life, most likely the range is bigger.
Mikrotik’s with SFP ports and Mikrotik SFP modules have been on the market for some time now. What are you guys finding with these units in regards to temperature handling. Are they standing up to the temperatures some of our outdoor enclosures on the inside?
I question such things even more with a recent heat related Cloudcore failure 3 months after installation, in a FM station bunker that can get to around 130F on a hot day even with a 15" industrial fan wall vent.
odie
August 27, 2014, 8:14am
4
Ours are not as hot…
a bit higher then the mainboardboard temp…
system health:
fan-mode: auto
use-fan: main
active-fan: main
cpu-overtemp-check: yes
cpu-overtemp-threshold: 100C
cpu-overtemp-startup-delay: 1m
voltage: 24V
current: 1599mA
fan-speed: 5688RPM
fan-speed2: 5875RPM
temperature: 40C
cpu-temperature: 55C
power-consumption: 38.4W
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: yes
rx-flow-control: yes
sfp-module-present: yes
sfp-rx-lose: no
sfp-tx-fault: no
sfp-connector-type: LC
sfp-link-length-9um: 80000m
sfp-vendor-name: Linksys
sfp-vendor-part-number: CWDM-SFP-1330
sfp-vendor-revision: 11.0
sfp-vendor-serial: 1206L00179
sfp-manufacturing-date: 12-06-11
sfp-wavelength: 1330nm
sfp-temperature: 44C
sfp-supply-voltage: 3.348V
sfp-tx-bias-current: 33mA
sfp-tx-power: 2dBm
sfp-rx-power: -18dBm
