What is the area size you want to cover? How many users, devices will be at the event? You wrote there is no existing network infrastructure, so what is your plan for internet connection?
There is no way (cost effective AND safe) that you can pass ethernet cables across a field/grass, unless there are poles and you can do something at a higher level than people.
Cables on the ground to be safe must be inside a protective conduit and either under the ground level (digged) or fixed with pegs (and 99% of the people will step on them, safe for the cables but not for the people).
There are objective limits to the number of devices that can connect to an AP, so the more AP's the better.
And - even if you use something wifi, you need anyway to power these devices (in theory you can couple a CPE to an AP back to back using - say 6 (or 60) GHz for the link to the "central spot" and 5 GHz and 2.4 GHz for the AP).
Or use devices similar to the Audience with three radios.
Since the duration of such temporary events is limited a possible solution would be using AP's mounted on (decently tall, let's say 3 m) poles on a basement that contain a big enough battery.
