Following this url
Specific (example) in the NAT Configuration section shows:
add chain=srcnat out-interface=ether1 action=masquerade
My wan interface uses sfp-sfpplus1. Should my cli reflect that difference as shown below?
add chain=srcnat out-interface=sfp-sfpplus1 action=masquerade
Thank you
Yes,
The name"ether1" is used as an example. replace it always with the name of interface you really use for WAN.
Remember that in that case the "sfp-sfpplus1" interface could be used elsewhere in the default configuration so you have to exclude it in proper way eg. remove from bridge if used in a bridge.
Excellent. thanks for the additional comment as well. Trying to document and build some muscle
memory to roll out these routers.
