Hello
First time posting here but i hope to get help with my issue of setting up the agent feature.
I tried the agent feature in local network with 2 routers and different networks on each and got the agent to work as it should (ping and snmp worked). But my real issue is getting agent to work over ipsec connection, that also has some firewall rules and so on.
If i open the router in dude and check the RouterOS status, it writes: “connection to agent xxx not ready (recv failed): Connection reset by peer(104)(6), next attempt at 07:23:24”. It there some port or something i have to allow in firewall?
