The Truth About Using Outdoor Laser Measure
Just before the modern era, the main indoor and outdoor laser measuring device is the tape measuring device. This device has quite a few limitations. First, it is a manual device that will take a long time to complete any measurement. Secondly, a tape measure may not be able to measure more than 10 feet and it will take so much energy and time to complete multiple measurements. Today, modern laser tape measures are super-fast and can measure in less than 0.3 seconds. Modern tape measures also come with modern features like Bluetooth for transferring measurements to other devices. Read the Outdoor Laser Measure Reviews - Top Laser Distance Meters on The Market
to learn more about modern laser measures. The following are the truth you should know about using outdoor laser measures;
Can I Use Any Laser Distance Measure Outdoor?
The simple answer to this is; Yes! All laser distance measures are designed to operate outdoors, but external factors can affect their efficiencies in different ways.
A laser measure emits a laser dot and this is reflected on the surface of your target before it is measured. You use physically see the laser dot, to know the point of your measurement. You need to know that there are laws that limit the output or intensity of your laser beam. Generally, most laser measures have an output of less than 1mW, which is also referred to as the general output for class 2 laser devices.
With this in mind, you can conclude that the brightness of one laser measure is pretty the same as the other. Unlike many brightness options you find in laser levels, there are no brightness options for laser measures. When using your laser measure outside, visibility will be greatly reduced and you may not see your laser beam more than 30 feet. You should check the maximum distance your laser measure can cover before buying it.
What Type of Distance Laser Measures Operate Outside?
Some laser measures are designed for working more efficiently outside. To achieve this, laser measures do have means of enhancing their target so that users will find out when a laser does hit its target. The telescopic optic fiber is one of the instruments used to enhance laser detection on target before measuring. The best outdoor laser measure will likely rely on an optic fiber telescopic accessory to operate.
Some laser measures do come with an optical viewfinder in-built, while others have these telescopes as a clip-on or attached accessory. When you look through the optic fiber telescope, you will notice a crosshair – this crosshair will indicate your laser has hit the target even if you can’t see the dot physically.
Some viewfinders can be very tricky to use, you will have to adjust the device even as you are viewing your laser dot. Once you view and detect the cross-hair you should press the measure button to start measuring. You may want to use a tripod to assist in detecting and measuring the laser dot.
One modern option of measuring laser dot with laser measure is the use of a video camera with an in-built screen. The camera is simply directed to where the laser is focused while the screen with a crosshair that will indicate where the laser dot is located.
The main advantage of using the video detection method is that it gives you more control over the direction in which you are pointing your laser measure. This option offers more accurate measurement and detection. You may not need this option when you are using the laser measure indoor.
Click on the link and check it out: Top Outdoor Laser Measure For Architects and Appraisers**
How to Target Your Outdoor Laser Measure Over a Long Distance
So, you have an optical viewfinder telescope or Video camera, you still have to find out how to position the laser where you want to measure. It is easier to use your laser measure with an optical viewfinder when targeting short distances but this is not the case with long-distance measurement. For long-distance measurements outdoors, you should consider using a tripod stand, and most especially a tiltable tripod that can help you adjust your camera.
To achieve even greater results, you should consider an adaptor for greater control. Some tripods do come with an adaptor for better control that can adjust left and right, up and down.
Is the Laser Measure Range Correct?
You cannot trust the maximum range of laser measure, because manufacturers don’t consider environmental factors such as excess bright light or sunshine and wind. Some laser measures may not be very effective during the winter season. You will be lucky if your laser measure can cover 75% of the range advertised by the manufacturer.
The reflective surface of your target object can affect the effectiveness of your laser measurement. A white-painted brick wall is more reflective than the dark color back of a tree. For this reason, you may find it more difficult to measure the distance to a white-colored surface.
The range is very important no doubt, but you cannot rely only on the effectiveness of your laser distance measure, you need the right accessory such as a tripod stand and an adapter to help you measure correctly.
Conclusion
It is important to find more product guides from laser distance meter review, where you can learn about top-rated laser measure brands. There are many brands of laser measures with different capacities. You should consider opting for a product that will come with the right accessories especially those that can extend the range and effectiveness of your laser measure.
You may want to have multiple laser distance measures you can test before you settle for the most appropriate for your situation. The laser measure for construction and other complex outdoor jobs should have a longer range and accuracy. Referring to the
Best Outdoor Laser Measure Reviews and Comparison for more information about choosing the right laser distance measures that suit your daily needs.
