hi balimore
i m very thankful to u for ur tips and its working nice.but i have still one question my dear
i hope u will help me to solve.
i m connecting two AP like this
AP1----------->mode=ap-bridge wds-mode=static
wlan1----------->10.1.0.1
ether1--------->10.1.2.1
bridge1---------->192.168.0.1
(wds1 and wlan1)
route----------->0.0.0.0/0 10.1.0.2
yes,
i must thinking easy config, easy maintenance, easy to connect, but must secure for user will connect to my network from wire or unwire. i have centralized aaa and must using 'transparant-network'.
my access points [Mikrotik] and other with wds support as ap or ap2ap
put all interfaces into bridge
put manage ip to bridge interface
put default gateway
put ip dns
my end stations [Mikrotik]
mode=station for wireless interface
put manage ip to wireless interface
dhcp server and local subnet
action=masquerade for ethernet user
put default gateway
put ip dns
my end station [nonMikrotik]
just making bridge network or than add simple router separately
my consepts, user must be easy without many config to their machine. simple mean must plug and play for user
i cant understand the mode !!! i was thinking that if i have a WDS mesh then ALL the NODES including the one which is connected to the internet will have the same configuration , the same mode … isnt it or not ??
the mesh is about let’s say 3 nodes each one has 2.4G for clients and 5.8G for link the 2 wlan + ethernet are bridged .
Hello frens
don't believed to me, but my suggestion working fine for my network and nice, simple with Mikrotik's router & wireless.
that methode as i want. and running since 14 months ago. great....
this's little report screen registration table for my second ap and you can see and i used 2,4ghz, ssid, freq
this ap action as ap2ap and ap2station with R52 one miniPCI and 13days uptime after updates ....43 version. i got signal -34 for ....E2 and ....34 when i am not decrease them.
on ethernet 8 unit workstations [factory]
mac-address: xxxxxxxxxxx:4A as static-wds connected to central ap distance 7,2km signal -49
mac-address: xxxxxxxxxxx:E2 as station distance 1,5km signal -62 5 unit workstations [office]
mac-address: xxxxxxxxxxx:34 as station distance 2,5km signal -61 2 unit workstations [resident]
