Hi!
TP-Link WN851ND does not work… It is supported?
Num. 4 in list… Why it not work?
[admin@P16] > sys reso pci pri det
0 device="02:0a.0" name="AR2413 802.11bg NIC (rev: 1)"
vendor="Atheros Communications Inc." category="Ethernet controller"
vendor-id="0x168c" device-id="0x001a" irq=11 memory=0xFF5B0000-0xFF5BFFFF
1 device="02:09.0" name="AR2413 802.11bg NIC (rev: 1)"
vendor-id="0x168c" device-id="0x001a" irq=11 memory=0xFF5C0000-0xFF5CFFFF
2 device="02:08.0" name="Atheros AR5001X+ Wireless Network Adapter (rev: 1)"
vendor-id="0x168c" device-id="0x0013" irq=11 memory=0xFF5D0000-0xFF5DFFFF
3 device="02:07.0" name="Atheros AR5001X+ Wireless Network Adapter (rev: 1)"
vendor-id="0x168c" device-id="0x0013" irq=9 memory=0xFF5E0000-0xFF5EFFFF
4 device="02:06.0" name="unknown device (rev: 1)"
vendor="Atheros Communications Inc." category="Network controller"
vendor-id="0x168c" device-id="0x002d" irq=11 memory=0xFF5F0000-0xFF5FFFFF
0ldman
January 25, 2012, 5:29am
2
What version of RouterOS are you running?
The other cards in the list are older A/B/G equipment, the new card is 802.11N. You must run v4 or above for N support.
[admin@P16] > sys reso pri
uptime: 12h32m45s
version: 5.12
free-memory: 237932KiB
total-memory: 255496KiB
cpu: AMD
cpu-count: 1
cpu-frequency: 2099MHz
cpu-load: 3%
free-hdd-space: 3741752KiB
total-hdd-space: 3851684KiB
write-sect-since-reboot: 1136
write-sect-total: 1136
architecture-name: x86
board-name: x86
platform: MikroTik
Is TL-WN851ND supported by mikrotik 5.18?
npero
October 2, 2013, 12:44pm
6
I have TP-Link TL-WN851N work fine on one of mine sites. Now running 6.4 on x86.
I don’t know what is difference between N and ND version.
When I have been on site can check hardware revision of PCI card.
npero:
i have problem! im install mikrotik 6.4. v but dont work tp link 851nd? any solution?
comp X86 intel pentium 4 2.66. ghz ! tanks
abkreno
January 26, 2015, 12:09am
8
Hi
I have Same Problem with TP-Link WN851ND , TP-Link WN851ND (rev: 1) does not work with mikrotik
I am use PC / X86, V 5.20 ,
What i can do to solve this problem ???
OS no detect the Card in interface list but it detect in resourse ==> PCI ==> Atheros Communications Inc. unknown device
version: 5.20
free-memory: 501268KiB
total-memory: 515648KiB
cpu: Intel(R)
cpu-count: 1
cpu-frequency: 2545MHz
cpu-load: 1%
free-hdd-space: 19015640KiB
total-hdd-space: 19233852KiB
write-sect-since-reboot: 870
write-sect-total: 870
board-name: x86
platform: MikroTik
system resource pci print
DEVICE VENDOR NAME IRQ
0 02:02.0 Atheros Communications Inc. unknown device (rev: 1) 10 <====
1 02:01.0 Realtek Semiconductor Co.,… RTL-8139/8139C/8139C+ (… 11
2 01:00.0 ATI Technologies Inc Radeon RV100 QY [Radeon… 5
3 00:1f.5 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 9
4 00:1f.3 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 9
5 00:1f.1 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 0
6 00:1f.0 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 0
7 00:1e.0 Intel Corporation 82801 PCI Bridge (rev: … 0
8 00:1d.7 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 6
9 00:1d.3 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 5
10 00:1d.2 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 11
11 00:1d.1 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 10
12 00:1d.0 Intel Corporation 82801EB/ER (ICH5/ICH5R)… 5
13 00:06.0 Intel Corporation 82865G/PE/P Processor t… 0
14 00:01.0 Intel Corporation 82865G/PE/P PCI to AGP … 0
15 00:00.0 Intel Corporation 82865G/PE/P DRAM Contro… 0
So Pleas I need Solution for This Problem
abkreno
January 26, 2015, 12:11am
9
Hi
version: 5.20
cpu: Intel(R)
cpu-count: 1
cpu-load: 1%
board-name: x86
platform: MikroTik
