Hi All,
Running 6.41rc4 and can’t get TR69 to work over https. Certificates imported and all. Anyone have the same problem (ie: bug?)
[nick@Mikrotik-673706B8FBE4] > /certificate print
Flags: K - private-key, D - dsa, L - crl, C - smart-card-key, A - authority, I - issued, R - revoked, E - expired, T - trusted
# NAME COMMON-NAME SUBJECT-ALT-NAME FINGERPRINT
0 L A T tmp_acs_ca_cert.txt_0 ACS-ROOT a569abb2ac0751e0f06fa60762adbce02ede66f48810d...
[nick@Mikrotik-673706B8FBE4] > /tr069-client prin
enabled: yes
acs-url: https://acs.xxx.nl/api/acs/ros/
username: test
password: test
periodic-inform-enabled: yes
periodic-inform-interval: 1d
connection-request-username:
connection-request-password:
client-certificate: none
status: running
last-session-error: SSL: handshake failed: unable to get local issuer certificate (6)
retry-count: 5
[nick@Mikrotik-673706B8FBE4] > /tool fetch keep-result=no mode=https check-certificate=yes-without-crl host="acs.xxx.nl" http-method=post http-data=$pdataEncoded url="https://acs.xxx.nl/api/"
status: finished
downloaded: 0KiBC-z pause]
duration: 0s
