Tracking and logging
hi,
can anyone help me with logging of netflow on MT hotspot.
Is it possible to log the following data with MT:
login time, flow id, source ip, destination ip, source port, destination port and protocol.
if yes, please tell me how to perform it?
Thanks :slight_smile:
As far as I know, traffic-flow provides standard information, you have to specify which data to monitor at your traffic-flow collector (I’m not sure login time will be shown there).
Go to ip, traffic flow and configure what you want. It is well documented in the manual.
The key is the collector sw. Here you need google :wink:
