Hi Forum,
I’m wanting to collect flows for multiple interfaces, to go to their individual targets.
If setting up multiple traffic flow targets, and multiple interfaces, is all flow data from all interfaces going to all targets? Is there a way to say x interface to y target and a interface to b target?
I only want to know as all collectors i’ve used store all data, and then just filter out the required info for display when you tell it the parameters, but this is inefficient as it will require storing much more flow data than wanted, and doubling up between the interfaces.
Is this something that could be looked at for next update, if its not currently possible?
Thanks.
