Dear All,
I am trying to block some sites i.e mega.io and tring to capture there service ip’s with the following RAW rule so i can block them, but there is now traffic/ip’s captured. On the other hand all the traffic is passing through the mikrotik with no clue. Can some one guide me on this.
The rules from the first post do not match that ones from the next post. You limit the second rules to ports 80 and 443 only.
Share your whole configuration but limiting https connections is not easy. Search forum for “block website etc.” … the ansewer is “you have to invest much more money”
In my second post i tried by adding ports too but it will not work. I think there might be some way to block those links, may be some one have some clue on it.
