Traffic Routing
Hello mates,
I have the following scenario, What i need to do is :
PC — Mikrotik1 ---- Mikrotik2
I dont need to maquerade traffic on MK1, what i need is only to make a route, and on MK2 i will masquerade
I did try to do that and what i got on the PC is DNS requests only… No internet
Whats the suitable things to do?
Thank you in advance.
Bill
Can you post more info about your setup, particularly IP addresses in use?
Here’s a sample config. You’ll have to modify it to work in your network.
MikroTik 1
add interface=ether1 address=10.1.1.1/24 comment"LAN subnet"
add interface=ether2 address=192.168.1.2/30 comment="Point-to-point router connection"
/ip route add gateway=192.168.1.1 comment="Default route to MikroTik 2"
MikroTik 2
add interface=ether1 address=192.0.2.2/24 comment="WAN to ISP"
add interface=ether2 address=192.168.1.1/30 comment="Point-to-point router connection"
/ip route dst-address=10.1.1.0/24 gateway=192.168.1.1 comment="Route to reach LAN subnet"
/ip route gateway=192.0.2.1 comment="ISP gateway"
add chain=srcnat action=masquerade out-interface=ether1 comment="NAT all traffic to Internet"
