Hello everyone, I hope I will find an answer here to my question…
I’m working with device that has an RJ45 connection for data transfer, its linsn led card
the card sending data to LED Panal
I’m try to use mikrotik switch between the card and the LED Panel, Isee The traffic coming in to the switch but i don’t know who to move it to different port
I try use bridge/ slave port and neither of them works, and i don’t know what the protocol i need to use
I would be happy if someone could tell me how you can send all the traffic coming in in port 1 to another port
No idea what that product is doing. You can try make the MikroTik behave like an old school hub by disabling MAC learning. If that doesn’t work I’d contact the manufacturer and try to determine what they are doing at lower layers of the OSI model and if they support any kind of signal repeating device.
