Hello all,
I have recently purchased a map lite for use as a travel router. The basic idea is that I plug it in whenerever I am and it tunnels back to my home router, broadcasts the same SSID as home and essentially provides the same LAN (DHCP, gateway, DNS, etc).
With this in mind, I thought the best way to accomplish it would be to use an SSTP VPN and then a EoIP tunnel through that, then adding the EoIP tunnel to the existing bridges.
The VPN is setup on the “home” router as follows:
/interface sstp-server server
set authentication=mschap2 certificate=Server enabled=yes pfs=yes tls-version=only-1.2
/ppp secret
add local-address=192.168.215.1 name=RemoteUser remote-address=192.168.215.2 service=sstp
and the client on the travel router:
/interface sstp-client
add add-default-route=yes authentication=mschap2 connect-to=SERIAL.sn.mynetname.net disabled=no name=sstp-out pfs=yes profile=default-encryption tls-version=only-1.2 user=RemoteUser
And works as it should, it connects and I can reach the assigned IPs (192.168.215.x) from each side.
EoIP on home router:
/interface eoip
add local-address=192.168.215.1 mac-address=02:AF:81:E4:17:32 mtu=1500 name=eoip-tunnel1 remote-address=192.168.215.2 tunnel-id=13
travel router:
/interface eoip
add local-address=192.168.215.2 mac-address=02:0D:6D:7E:17:FA mtu=1500 name=eoip-tunnel1 remote-address=192.168.215.1 tunnel-id=1
I’ve added the EoIP tunnel to my bridge on the home router but its listed as a disabled port:
As I understand theres not a way to monitor if the EoIP is up or not? I see occasional traffic on the interface window, I assume thats it trying to establish, but nothing consistent.
I’ve added the EoIP interface to the bridge on the travel router to the same effect. When I connect a client to the travel router SSID I don’t get assigned an IP address.
If I assign the travel router an address and setup a DHCP server, clients can connect and work as expected so I hopefully haven’t setup the travel router incorrectly.
What am I missing? Have I setup the EoIP tunnel incorrectly or have I misunderstood something and am going about the in the wrong way? Is there a better way to do this?
Thanks in advance for your help
