I am in a big trouble.
My setup is ATL → hAP3 → LAN.
What I did:
- I have updated the hAP3:
/system/package/update/download
/system/routerboard/upgrade
Everything went fine and 7.16 works after the reboot.
- I have updated the ATL:
Update was successful.
Then I rebooted.
RESULT: I can no longer connect to the ATL (I always use only SSH and that is the only enabled method):
ssh: connect to host 192.168.188.1 port 22022: Network is unreachable
I cannot even ping the ATL from the hAP3 (which powers it) or from the computer. I get packet-loss=100%. No configuration was touched before or after the update.
At the same time, I see that the LED of on the hAP3 port to which the ATL is connected is lit, i.e. there is connection on L1. From time to time that led goes dark for 2-3 seconds but then it is on again.
I tried connecting the ATL cable directly to the computer (using the PoE injector supplied with the ATL) but again - no connection is possible.
The problem:
My ATL is on a very high pole and it is impossible to reset it via the button. A reset would need unmounting of the whole construction.
I don’t know why the update caused this but now I have no Internet connection because the ATL cannot be used. I am sending this using my phone Internet.
Please kindly advise how to proceed.
