Hey I am trying to set up a WPA2/3 EAP authentication for an admin subnet. I am using an upstream Free Radius server on my PFsense router and have my downstream HAP AX3 act as the access point to the subnet through the SaaSquach SSID. But The SSID is not broadcasting.
/interface wifi monitor : Says the SSID is Running.
add admin-mac=78:9A:18:13:ED:B3 auto-mac=no comment=defconf name=bridge
vlan-filtering=yes
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=
10min-cac .width=20/40/80mhz configuration.dtim-period=3 .mode=ap .ssid=
"VOID Home" .tx-power=20 datapath.bridge=bridge .client-isolation=yes
disabled=no name="Home HF" security.authentication-types=
wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=
10min-cac .width=20/40mhz configuration.dtim-period=3 .mode=ap .ssid=
"VOID Home" .tx-power=14 datapath.bridge=bridge .client-isolation=yes
disabled=no name="Home LF" security.authentication-types=
add configuration.mode=ap .ssid="VOID IoT" datapath.bridge=bridge
.client-isolation=yes .vlan-id=3 disabled=no mac-address=
7A:9A:18:13:ED:B8 master-interface="Home LF" name=IoT
security.authentication-types=wpa-psk,wpa2-psk
/interface vlan
add interface=bridge name=BridgeMgmt vlan-id=42
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi aaa
add disabled=no name=RADIUS-AAA
/interface wifi security
add authentication-types=wpa2-eap,wpa3-eap disabled=no encryption=
ccmp,gcmp,ccmp-256,gcmp-256 group-encryption=ccmp management-protection=
allowed name="Enterprise "
/interface wifi
add aaa=RADIUS-AAA configuration.mode=ap .ssid=SaaSquach datapath.bridge=
bridge .vlan-id=42 disabled=no mac-address=7A:9A:18:13:ED:B7
master-interface="Home HF" name=Admin security="Enterprise "
security.authentication-types=wpa2-eap,wpa3-eap .encryption=
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
source="\r
\n :if ([system leds settings get all-leds-off] = "never") do={\r
\n /system leds settings set all-leds-off=immediate \r
\n } else={\r
\n /system leds settings set all-leds-off=never \r
\n }\r
\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys
source="\r
\n :foreach iface in=[/interface/wifi find where (configuration.mode="a
p" && disabled=no)] do={\r
\n /interface/wifi wps-push-button $iface;}\r
\n "
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether5 pvid=5
add bridge=bridge comment=defconf interface="Home HF" pvid=5
add bridge=bridge comment=defconf interface="Home LF" pvid=5
add bridge=bridge interface=ether1
set add-dns-entries=yes discover-interface-list=LAN
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 untagged=Admin,ether5 vlan-ids=42
add bridge=bridge tagged=bridge,ether1 untagged="Home HF,Home LF" vlan-ids=5
add bridge=bridge tagged=bridge,ether1 untagged=IoT vlan-ids=3
add comment=defconf interface=ether1 list=LAN
add interface=ether5 list=LAN
add interface="Home LF" list=LAN
add interface="Home HF" list=LAN
add interface=IoT list=LAN
add interface=Admin list=LAN
/ip dhcp-client
add interface=BridgeMgmt name=client1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
in-interface=lo src-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN"
disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/radius
add address=10.42.42.1 require-message-auth=no service=login,wireless,dot1x
src-address=10.42.42.50
/system clock
set time-zone-name=America/Toronto
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/tool mac-server
/tool mac-server mac-winbox
