TrueCafe with HapLite.
Well as stand alone its working fine. Using the pre configured settings.
But when connecting other PC through this router it’s can’t connect to terminal pcs.
Well this software uses port 15925 for client pc and something 15900-15999 for server pc.
Setup :- The pc (Truecafe and print server, w7 os) is sharing ICs through lan which is connected to HapLite.
Hap is the gateway/connected through lan/ to my other pc ( truecafe client.)
USB Modem(Internet) >> W7(For sharing internet and server for true cafe.)>>Haplite(DHCP,shaping, gateway)
Problem:
The problem I am facing is truecafe client can connect to server using haplits ip(192.168.137.54) but server cannot communicate with them.
please help.
Can you post your config export
Here is the exported file attached .
Please help me with this.
Thanks in advance.
Exported file.
17_03_2016_mod.rsc
Please help me with this,i am stuck in here.
Try Add
====Firewall NAT===
add action=masquerade chain=srcnat out-interface=bridge2
Thanks its now working.
