For everyone who want to clear proxy cache, try the follwing scripts.
1- add thescript
if you have ver 3.x then use: (tested and works!)
/system script add name=script_clear_cache source="/ip proxy clear-cache"
if you have ver 2.x (not tested)
/system script add name="script_clear_cache " source={
/ip firewall nat disable [find action=redirect]
/ip web-proxy set enabled=no
/ip web-proxy clear-cache
/ip web-proxy set enabled=yes
/ip firewall nat enable [find action=redirect]
2-scheduler
now we come to the scheduler: which will run the script (script_clear_cache)
/system scheduler
add comment="" disabled=no interval=1d name=clear_proxy_cache on-event=script_clear_cache start-date=Jan/01/1970 start-time=00:00:00
Note her: interval=1d
this is the interval for the script to run, i use it everyday. if you want it weekly just use: interval=7d for monthly user: interval=30d
The start date: start-date=Jan/01/1970 is the date when the script to start. you can use future date like: sep/30/2009 etc..
good luck everybody
Chupaka
September 3, 2009, 2:16pm
2
just interesting: why do you need that?..
fewi
September 3, 2009, 3:25pm
3
Maybe I’m missing something here, but couldn’t you just set
max-fresh-time (time; default: 3d) - an upper limit on how long objects without an explicit expiry
time will be considered fresh
to 1 day and have objects expire from the cache dynamically without needing a script?
chapex
September 5, 2009, 4:44pm
4
It would be good that the clean does after coming to a certain volume. In case of the SD it would take better of the useful life. (memory celds)
regards
chapex
September 5, 2009, 5:54pm
6
Chupaka:
better?.. why?..
vanilla kernel does not good management on memories of limited use. It’s not performed fot that. That’s why after reaching the top of capacity, there was a drain, not to be writing constantly on the same cells.
regards
karina
April 26, 2013, 8:51am
7
I think Script is required as the dynamic expiry seems to fail. My webproxy is set to 3d max fresh however when I look in proxy contents there are many objects over 7 days old and more, or am I missing something
