trying bootp protocol......... failed kernel loading failed
RouterBOOT booter 2.41
RouterBoard 450G
CPU frequency: 680 MHz
Memory size: 256 MB
Press any key within 2 seconds to enter setup..
Ethernet link absent…
trying bootp protocol… failed
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000001 cfe0ebb8 00000000
$ 4 : c0378f3c 00000def ffffffff c03c0bac
$ 8 : c03c4c7f c03c4c7f 00000008 2d646972
$12 : 6e672074 c0312464 000000bd 6f206164
$16 : cfe0eb98 cfd85e84 cfe0ebb8 00000001
$20 : cfc29c40 00000004 ffffffff c0345ea0
$24 : 00000018 c025f9f0
$28 : cfc28000 cfc29c10 c0380000 c01e1c20
Hi : 00000039
Lo : 00000005
epc : c01e1ca8 yaffs_AddObjectToDirectory+0x114/0x188
Not tainted
ra : c01e1c20 yaffs_AddObjectToDirectory+0x8c/0x188
Status: 1000c203 KERNEL EXL IE
Cause : 0080000c
BadVA : 00000004
PrId : 00019374 (MIPS 24Kc)
Process init (pid: 1, threadinfo=cfc28000, task=cfc20000, tls=00000000)
Stack : cfc0d000 cfe0eb98 00000003 00000000 cfc0d000 00000000 00000000 c01e4920
c03453c1 00000001 cfd2f800 c0196894 ffffffff 0000001c 000016ad 00000539
000067ea 6183001b 00000000 00000313 00000000 00012b37 00000000 cfc0d000
cfe0eb08 cfe0eb98 cfc0d000 cfc0d000 0000000a 0000001c cfd12efc 00000000
00000000 00000000 7ff80c20 c01e7d5c cfc29d60 c0216f44 c0338cbd c020bccc
Call Trace:
[] yaffs_AddObjectToDirectory+0x114/0x188
[] yaffs_CheckpointRestore+0x1f4/0x42c
[] yaffs_GutsInitialise+0x4f4/0x1e94
[] yaffs_internal_read_super+0x6e8/0x828
[] yaffs_internal_read_super_mtd+0x14/0x2c
[] get_sb_bdev+0x138/0x1b0
[] yaffs_read_super+0x20/0x2c
[] vfs_kern_mount+0x68/0x11c
[] do_kern_mount+0x48/0x100
[] do_mount+0x620/0x694
[] sys_mount+0x8c/0xf0
[] stack_done+0x20/0x3c
Code: ae00001c 8e230068 26020020 ae030020 26230068 ae030024 ae22
0068 8e020008
—[ end trace 7779c71bebc99eee ]—
Kernel panic - not syncing: Attempted to kill init!
help me
do a netinstall.
yes i want
Then You need to try another netinstall/software version.
it cannot show in the Netinstall Pleas tell me what is default ip address for net booting & Enable r disable
