Trying to setup an x86 unit
Hi all,
So after doing a bit of research here in the forums, I’m going to assume I’m ‘beating a dead horse” (a saying we have here in the US).
But I was hoping to turn a nice little mini pc I’ve got into a RouterOS unit. It has multiple LAN ports and RouterOS installed fine on it. I got everything working except the Wireless. It originally had an Intel Mini PCIe card in it. That’s when I found out they RouterOS doesn’t support Intel. So I went down the rabbit hole of trying to find a Atheros based unit that would work in the unit which I did. Got it in this evening and put it in.
The RouterOS is seeing the device in resources, but apparently it doesn’t have drivers for it in the OS. It is a QCA6174. Here are what I think might be all anyone would need to see what the setup is on the mini pc I’m working with.
Is this a fools errand and should I just get a standalone AP and not worry about wireless on the mikrotik unit?
My reason for doing this, is I got one of the newer l009uigs-2haxd-in only to find out that it only supports 2.4 wireless. I was hoping to see some 5Ghz wireless.
Thanks in advance!
Ken
[admin@MikroTik] > /system/resource print
                   uptime: 1h31m22s
                  version: 7.20.5 (stable)
               build-time: 2025-11-27 08:17:04
         factory-software: 7.1
              free-memory: 7.5GiB
             total-memory: 7.9GiB
                      cpu: Intel(R)
                cpu-count: 4
            cpu-frequency: 1596MHz
                 cpu-load: 0%
           free-hdd-space: 118.2GiB
          total-hdd-space: 118.2GiB
  write-sect-since-reboot: 720
         write-sect-total: 720
        architecture-name: x86_64
               board-name: x86 Intel H81U
                 platform: MikroTik
Config header:
# 2025-12-03 00:51:06 by RouterOS 7.20.5
# software id = **ELIDED**
Hardware:
Flags: I - inactive
 0   location="0000:00:00.0" type=pci vendor="Intel Corporation"
     name="Haswell-ULT DRAM Controller (rev: 11)" category="Host bridge"
     vendor-id="0x8086" device-id="0x0a04" irq=0 device-path=""
 1   location="0000:00:02.0" type=pci vendor="Intel Corporation"
     name="Haswell-ULT Integrated Graphics Controller (rev: 11)"
     category="VGA compatible controller" vendor-id="0x8086" device-id="0x0a16"
     irq=11 memory=0xA7C00000-0xA7FFFFFF,0xB0000000-0xBFFFFFFF io=0x5000-0x503F
     device-path=""
 2   location="0000:00:03.0" type=pci vendor="Intel Corporation"
     name="Haswell-ULT HD Audio Controller (rev: 11)" category="Audio device"
     vendor-id="0x8086" device-id="0x0a0c" irq=11 memory=0xA8414000-0xA8417FFF
     device-path=""
 3   location="0000:00:14.0" type=pci vendor="Intel Corporation"
     name="8 Series USB xHCI HC (rev: 4)" category="USB controller"
     vendor-id="0x8086" device-id="0x9c31" irq=11 memory=0xA8400000-0xA840FFFF
     device-path=""
 4   location="2-0" parent=0000:00:14.0 type=usb vendor="Linux 5.6.3-64 xhci-hcd"
     name="xHCI Host Controller" serial-number="0000:00:14.0" vendor-id="0x1d6b"
     device-id="0x0002" speed="480" ports=8 usb-version=" 2.00" irq=0
     device-path=bus/usb/002/001
 5   location="2-1" parent=2-0 type=usb name="USB 2.0 Hub" vendor-id="0x1a40"
     device-id="0x0101" speed="480" ports=4 usb-version=" 2.00" irq=0
     device-path=bus/usb/002/002
 6   location="2-1.4" parent=2-1 type=usb vendor-id="0x0cf3" device-id="0xe300"
     speed="12" usb-version=" 2.01" irq=0 owner="system" device-path=""
 7   location="2-5" parent=2-0 type=usb vendor=" " name="mini keyboard"
     vendor-id="0x1997" device-id="0x2433" speed="12" usb-version=" 1.10" irq=0
     device-path=bus/usb/002/003
 8   location="3-0" parent=0000:00:14.0 type=usb vendor="Linux 5.6.3-64 xhci-hcd"
     device-id="0x0003" speed="5000" ports=4 usb-version=" 3.00" irq=0
     device-path=bus/usb/003/001
 9   location="0000:00:16.0" type=pci vendor="Intel Corporation"
     name="8 Series HECI #0 (rev: 4)" category="Communication controller"
     vendor-id="0x8086" device-id="0x9c3a" irq=11 memory=0xA841C000-0xA841C01F
     device-path=""
10   location="0000:00:1b.0" type=pci vendor="Intel Corporation"
     name="8 Series HD Audio Controller (rev: 4)" category="Audio device"
     vendor-id="0x8086" device-id="0x9c20" irq=5 memory=0xA8410000-0xA8413FFF
     device-path=""
11   location="0000:00:1c.0" type=pci vendor="Intel Corporation"
     name="8 Series PCI Express Root Port 3 (rev: 228)" category="PCI bridge"
     vendor-id="0x8086" device-id="0x9c14" speed="1x2.5 GT/s" irq=11
     device-path=""
12   location="0000:01:00.0" parent=0000:00:1c.0 type=pci
     vendor="Realtek Semiconductor Co., Ltd."
     name="RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev: 21)"
     category="Ethernet controller" vendor-id="0x10ec" device-id="0x8168"
     memory=0xA8304000-0xA8304FFF,0xA8300000-0xA83FFFFF io=0x4000-0x4FFF
     device-path=""
13   location="0000:00:1c.3" type=pci vendor="Intel Corporation"
     name="8 Series PCI Express Root Port 4 (rev: 228)" category="PCI bridge"
     vendor-id="0x8086" device-id="0x9c16" speed="1x2.5 GT/s" irq=10
     device-path=""
14   location="0000:02:00.0" parent=0000:00:1c.3 type=pci
     vendor="Qualcomm Atheros"
     name="QCA6174 802.11ac Wireless Network Adapter (rev: 50)"
     category="Network controller" vendor-id="0x168c" device-id="0x003e"
     speed="1x2.5 GT/s" irq=10 memory=0xA8000000-0xA81FFFFF device-path=""
15   location="0000:00:1c.4" type=pci vendor="Intel Corporation"
     name="8 Series PCI Express Root Port 5 (rev: 228)" category="PCI bridge"
     vendor-id="0x8086" device-id="0x9c18" speed="1x2.5 GT/s" irq=11
     device-path=""
16   location="0000:03:00.0" parent=0000:00:1c.4 type=pci
     memory=0xA8204000-0xA8204FFF,0xA8200000-0xA82FFFFF io=0x3000-0x3FFF
     device-path=""
17   location="0000:00:1d.0" type=pci vendor="Intel Corporation"
     name="8 Series USB EHCI #1 (rev: 4)" category="USB controller"
     vendor-id="0x8086" device-id="0x9c26" irq=10 memory=0xA841A000-0xA841A3FF
     device-path=""
18   location="1-0" parent=0000:00:1d.0 type=usb vendor="Linux 5.6.3-64 ehci_hcd"
     name="EHCI Host Controller" serial-number="0000:00:1d.0" vendor-id="0x1d6b"
     device-id="0x0002" speed="480" ports=2 usb-version=" 2.00" irq=0
     device-path=bus/usb/001/001
19   location="1-1" parent=1-0 type=usb vendor-id="0x8087" device-id="0x8000"
     speed="480" ports=8 usb-version=" 2.00" irq=0 device-path=bus/usb/001/002
20   location="0000:00:1f.0" type=pci vendor="Intel Corporation"
     name="8 Series LPC Controller (rev: 4)" category="ISA bridge"
     vendor-id="0x8086" device-id="0x9c45" irq=0 device-path=""
21   location="0000:00:1f.2" type=pci vendor="Intel Corporation"
     name="8 Series SATA Controller 1 [AHCI mode] (rev: 4)"
     category="SATA controller" vendor-id="0x8086" device-id="0x9c03" irq=10
     memory=0xA8419000-0xA84197FF io=0x5060-0x507F device-path=sda2,sda1,sda
22   location="0000:00:1f.3" type=pci vendor="Intel Corporation"
     name="8 Series SMBus Controller (rev: 4)" category="SMBus"
     vendor-id="0x8086" device-id="0x9c22" irq=11 memory=0xA8418000-0xA84180FF
     io=0x5040-0x505F device-path=""
Completely illogical.
First you find out what the software supports, then you buy the hardware.
Or rather, you buy the hardware from the company that makes the software, so it's plausibly guaranteed to be supported.
There is a list here of surely working modems:
The QCA6174 is not among them.
The list may be incomplete, but those mentioned there should be surely compatible.
Try procuring a QCA9888 or QCA9984 card.
Now what kind of human would I be if I were to approach this in a “logical” fashion. :slight_smile: You’d be erasing decades of touching the electric fence to see if it’s on vs using a tester to check for voltage.
Yep, but touching It again 10 minutes later to see if there Is still voltage has traditionally been frowned upon.
Found one of these and got it ordered. Looking forward to getting this fired up (and touching that electric fence a few more times) :rofl: Thanks everyone for the insight. And a special thanks to Spock… I mean rextended.
Live long and prosper
... boldly testing new, strange, wifi cards ... :wink:
So quick update in case anyone else attempting the x86 thing and wanting wifi… don’t. We had the funeral for this dead horse today. There was a lot of sadness, and I’ll probably be grieving for a while. But hey, time to move on. :slight_smile:
I think if I decide to do something again with an x86 unit, I’ll scratch the idea that it will have wifi and put in a ceiling AP or something like that.
Thanks again for the advice.
Regards,
Ken
I suggest not to waste time and money to get a working wifi in x86 unit. Even you got one from Mikrotik, it may not be able to make it working. I tried before. Dual band wifi card found but never able to make it work.
File support and told me that they would look into and get an update.
I have not heard from them. Nor I put back the mikrotik wifi card into the x86 unit.
Get an AC2 or AX2 for the wifi you need. Perhaps better an AP from others.
Gentlemen, I just bought a motherboard that would be perfect, a 2.5-inch x86 board. It would be perfect, I regret only reading this thread now. Will RouterOS run on any other ARM motherboard?
