ElTRiC
March 11, 2019, 6:04pm
1
Hello people,
I’ve bought a hAP lite router to provide load-balancing on two ISP (DSL and LTE).
First I’ve tried with ECMP, load blanacing worked but I also had huge timeout and certificates not working. So I tried PCC.
I’m on like my 5th try, everything seems fine, failover works but the router never uses the second ISP to lad-balance network traffic.
I have triple checked my config, with systemzone tutorials, mikrotik WIKI and honestly I can’t understand why it won’t work
Here is my config , I hope someone can help (replaced sensitive information with xxxx) .
# mar/11/2019 18:41:51 by RouterOS 6.43.8
# software id = 9ZJP-QWH1
# model = RouterBOARD 941-2nD
# serial number = A1C309C13EC4
add admin-mac=xxxx auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
xxxx wireless-protocol=802.11
set [ find default-name=ether3 ] name=Disabled
set [ find default-name=ether4 ] name=LAN_LOGIN_GATE
set [ find default-name=ether2 ] name=WAN_4G
set [ find default-name=ether1 ] name=WAN_DSL
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
xxxx wpa2-pre-shared-key=xxxx
add name=dhcp ranges=192.168.0.10-192.168.0.220
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=LAN_LOGIN_GATE
add comment=defconf interface=WAN_DSL list=WAN
add interface=WAN_4G list=WAN
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.2.100/24 interface=WAN_DSL network=192.168.2.0
add address=192.168.1.100/24 interface=WAN_4G network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=WAN_DSL
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.0.1 name=router.lan
add address=192.168.2.1 name=mabox.bytel.fr
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.2.0/24 in-interface=\
bridge
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=\
bridge
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=WAN_DSL new-connection-mark=WAN_DSL_conn passthrough=no
in-interface=WAN_4G new-connection-mark=WAN_4G_conn passthrough=no
dst-address-type=!local in-interface=bridge new-connection-mark=\
WAN_DSL_conn passthrough=no per-connection-classifier=both-addresses:2/0
WAN_4G_conn passthrough=no per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN_DSL_conn \
in-interface=bridge new-routing-mark=to_WAN_DSL passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN_4G_conn \
in-interface=bridge new-routing-mark=to_WAN_4G passthrough=no
add action=mark-routing chain=output connection-mark=WAN_DSL_conn \
add action=mark-routing chain=output connection-mark=WAN_4G_conn \
add action=fasttrack-connection chain=forward connection-mark=!WAN_4G_conn \
add action=masquerade chain=srcnat out-interface=WAN_4G
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN_DSL
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_WAN_4G
add check-gateway=ping distance=2 gateway=192.168.1.1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=WAN_DSL type=external
add interface=WAN_4G type=external
/system clock
set time-zone-name=Europe/Paris
/system ntp client
set enabled=yes primary-ntp=178.249.167.0 secondary-ntp=212.83.158.83 \
server-dns-names=""
/tool mac-server
/tool mac-server mac-winbox
You masquerade twice WAN 4G! and not DSL?
3rd and 4th route, increase the distance by one for each (only keep the routing marking routes at distance 1)
In mangle you need to set passthrough “yes” as you mangle packets afterwards further.
if you use PCC with both address mode, need to put RP filter mode to “loose” (in firewall/tracking settings somewhere).
Please report back progress
ElTRiC
March 12, 2019, 7:23pm
3
Masquerade had some weird glitch, or I fumbled around with copy/paste because both wan were ofc masquerade ^^
Changed stuff you told me, but now browsing is veeery slow and got timeouts on SSL/TLS
it works fine when disabling one WAN… (needed to do this to post here)
Here after the new config :
/ip settings
set rp-filter=loose
192.168.0.0
/ip dhcp-client
/ip dns static
invalid
/ip firewall mangle
bridge
bridge
in-interface=WAN_DSL new-connection-mark=WAN_DSL_conn passthrough=yes
in-interface=WAN_4G new-connection-mark=WAN_4G_conn passthrough=yes
WAN_DSL_conn passthrough=yes per-connection-classifier=both-addresses:2/0
WAN_4G_conn passthrough=yes per-connection-classifier=both-addresses:2/1
in-interface=bridge new-routing-mark=to_WAN_DSL passthrough=yes
in-interface=bridge new-routing-mark=to_WAN_4G passthrough=yes
add action=masquerade chain=srcnat out-interface=WAN_DSL
add check-gateway=ping distance=2 gateway=192.168.2.1
/ip upnp
set enabled=yes
/ip upnp interfaces
/system clock
/system ntp client
server-dns-names=""
/tool mac-server
SSL / https breaks if you do not set connection tracking (RP filter) to loose mode.
Or if that is not the case, first try with PCC “source address only” and see if that works.
Normally SSL should then work.
ElTRiC
March 13, 2019, 6:23pm
5
/ip settings
set rp-filter=loose
It’s already set on loose. Where can I set “PCC “source address only”” ?
To use mangle you need to disable fast track firewall connection. !!!
Remove tha firewall rule and reboot!!!
Without that packets will bypass mangle!
Please check again.
PCC: In the settings Firewall - Mangle - Advance settings - Per Connection Classifier , you select “source” or “both”.
But I am pretty sure your issue is Fasttrack.
ElTRiC
March 18, 2019, 3:55pm
7
I have disabled fastrack, but to be honest I already tried that before because I have found a topic about fasttrack and pcc and it was told there that if you exclude wan2 from fasttrack it can work…
http://forum.mikrotik.com/t/navigation-issue-with-fasttrack-in-conjunction-with-pcc/100156/1
But… I created this exclusion rule in mangle and not in filter rules, maybe that’s the issue ?
Need to test more…
Another question, can I force an IP or (better for me) a mac adress to use only a selected WAN ? Actually it’s to force my DSL tvbox to use dsl only, my whitebox to use dsl only and one server to use lte only because upload is way better.
ElTRiC
March 18, 2019, 4:04pm
8
Update. It seems to work with fasttrack disabled, I was able to speedtest WAN_4G while WAN_DSL was on as well !
Now I’ll do some test later with fasttrack on only for dsl.
If you have some idea how to force an ip or mac adress through a specific wan it would be awesome !
Thanks for your help so far
anav
March 18, 2019, 6:38pm
9
Well the easiest would probably be not to mangle that traffic from that IP address and then it will get routed out the main table on the route where wan distance=1.
Thus if you wanted user x to use WAN3, and you had no other funky requirements.
Just set distance =1 for wan3, 2 for wan1, 3 for wan2, 4 for wan4 and so on… the order is arbitrary anyway.
In mangle rules
Ensure this is a first rule
/ip firewall mangle.
add action=accept source address=specific IP address (or source-address-list if you have a few)
out-interface-list=WAN.
Thus this traffic will exit out the mangle rules and thus not be marked and thus will use the main routing table… That is my GUESS.
YES, I do not know for sure… Think of it as an educated rumour LOL.
ElTRiC
March 19, 2019, 3:24pm
10
I’ve found this : https://wiki.mikrotik.com/wiki/Policy_Base_Routing
Is it the same process with a single IP and not some content (even if I think about using this to force youtube through WAN_4G )
ElTRiC
March 20, 2019, 3:40pm
11
Hum this morning I had a first issue with failover.
My WAN boxes don’t have bridge option, so I access to it through a local IP (192.168.1.1 or 192.168.2.1).
Problem, if internet doesn’t connect/work/whatever the local adress is still answering and mikrotik does consider that WAN is UP even if it’s not.
I don’t see any other options than ping or arp in “check gateway” route options, like giving a DNS server to check… Any idea for me ?
Hi sir ElTRiC can you help me. can you share you config… I’m just a newbie when it comes with mikrotik.. and I need to reconfigure my old hap lite with dual isp all in LTE with 5mbs and 10mbs speed.
thank you in advance
ElTRiC
July 12, 2019, 9:20am
13
Hi Cloneako,
Sorry for late answer, still need my config shared ?
Yes sir. I still need it..
