To recap you have a single subnet coming in from an upstream device. Is it coming on a vlan tagged port on the upstream device or simply as a subnet connected on the etherport??
Either way this upstream source has two flows to perform, reach your router and is terminated as its IP DHCP client and also to move to ports 5,6,7,8.
Thus you will have to make the incoming port a trunk port if already coming to you as a tagged vlan or as an access port if coming as an untagged stream of traffic. I will assume the latter.
Personally, for now I would use port 8 to configure the router from a safe spot and from which to eventually turn on vlan-filtering on the bridge. Rename the port to be clear....
From the default config,
Remove ether8 from the bridge
give it an IP address 192.168.77.130 interface=OffBridge8 network=192.168.77.0
ensure its part of a trusted and LAN interface
plug in your laptop and change ipv4 settings to 192.168.77.2 and you should be able to access the router.
add admin-mac=auto-mac=no comment=defconf name=bridge \
port-cost-mode=short vlan-filtering=no { modify to 'yes' as last item on the config }
set [ find default-name=ether1 ] name=ether1WAN
set [ find default-name=ether8 ] name=OffBridge8
/interface vlan
add interface=bridge name=SourceVLAN vlan-id=10
add interface=bridge name=vlan20-home vlan-id=20 comment="for home wired and wifi"
add interface=bridge name=vlan30-guest vlan-id=30 comment="for guest wifi"
add interface=bridge name=vlan40-iot vlan-id=40 comment="for iot wifi devices"
add comment=defconf name=WAN
add name=LAN
add name=TRUSTED
/interface wifi channel
add band=2ghz-ax name=wifi1-home2ghz
add band=5ghz-ax name=wifi2-home5GHZ
add band=5ghz-ax name=wifi3-guest5GHZ
add band=2ghz-ax name=wifi4-iot2ghz
/interface wifi security
/interface wifi configuration
add name=dhcp_HOME_pool ranges=192.168.20.2-192.168.2.254
add name=dhcp_GUEST_pool ranges=192.168.30.2-192.168.1.254
add name=dhcp_IOT_pool ranges=192.168.40.2-192.168.2.254
add address-pool=dhcp_HOME_pool interface=vlan20-home lease-time=8h \
name=HOME-server
add address-pool=dhcp_GUEST_pool interface=vlan30-guest lease-time=8h \
name=GUEST-server
add address-pool=dhcp_IOT_pool interface=vlan40-iot lease-time=8h \
name=IOT-server
set discover-interface-list=TRUSTED
add bridge=bridge ingress-filtering=yes frame-types=admit-only-untagged-and-priority \
interface=ether1WAN pvid=10
interface=ether2 pvid=20 comment="home pc"
interface=ether3 pvid=20 comment="home printer"
interface=ether4 pvid=20 comment="home unmanaged switch"
interface=wifi1-home2ghz pvid=20 comment="home wifi 2ghz"
interface=wifi2-home5GHZ pvid=20 comment="home wifi 5GHZ"
interface=wifi3-guest5GHZ pvid=30 comment="guest-wifi 5GHZ"
interface=wifi4-iot2ghz pvid=40 comment="iot-wifi 2ghz"
interface=ether5 pvid=10
interface=ether6 pvid=10
interface=ether7 pvid=10
/ip dhcp client
add default-route=yes interface=SourceVLAN
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=ether1WAN,ether5,ether6,ether7 vlan-id=10
add bridge=bridge tagged=brdige untagged=ether2,ether3,ether4,wifi1-home2ghz,wifi2-home5GHZ vlan-id=20
add bridge=bridge tagged=bridge untagged=wifi3-guest5GHZ vlan-id=30
add bridge=bridge tagged=bridge untagged=wifi4-iot-2ghz vlan-id=30
add comment=defconf interface=SourceVLAN list=WAN
add interface=vlan20-home list=LAN
add interface=vlan30-guest list=LAN
add interface=vlan40-iot list=LAN
add interface=OffBridge8 list=LAN
add interface=vlan20-home list=TRUSTED
add interface=OffBridge8 list=TRUSTED
add address=192.168.20.1/24 interface=vlan20-home network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30-guest network=192.168.30.0
add address=192.168.40.1/24 interface=vlan40-iot network=192.168.40.0
add address=192.168.77.1/30 interface=OffBridge8 network=192.168.77.0
set server=192.168.10.1
add action=accept chain=inputconnection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input dst-address=127.0.0.1
add action=accept chain=input comment="admin" in-interface-list=TRUSTED
add action=accept chain=input comment="users to services" in-interface-list=LAN \
dst-port=53 protocol=udp
dst-port=53 protocol=tcp
add action=drop chain=input comment="drop all else"
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward comment="internet traffic" out-interface-list=WAN
add action=accept chain=forward comment="admin to lans" in-interface-list=TRUSTED out-interface-list=LAN
add action=drop chain=forward comment="drop all else"
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
This example includes 3 vlans behind your router and the one subnet coming in.
This example includes four wifi SSIDs, two for home, one for guest and one for iot.
