Two bugs encountered on RB5009UG+S+ and RB4011iGS+ recently
Static CNAME DNS Entry has to be flattened
The first is with the DNS Server, reported in MikroTik SUP-192131, "is identified and will be addressed in further RouterOS releases."
git.kernel.org. resolves as the following in my region...
kexybiscuit@ProArtB550-CREATOR [ linux@master ] $ dig git.kernel.org
; <<>> DiG 9.20.4 <<>> git.kernel.org
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 31730
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 6, ADDITIONAL: 6
;; QUESTION SECTION:
;git.kernel.org.                        IN      A
;; ANSWER SECTION:
git.kernel.org.         1686    IN      CNAME   geo.source.kernel.org.
geo.source.kernel.org.  600     IN      CNAME   sg2.source.kernel.org.
sg2.source.kernel.org.  1686    IN      A       172.236.150.65
However, I'd like geo.source.kernel.org. to be resolved to sea.source.kernel.org., since sg2.source.kernel.org. is unusable in my region due to international link congestion.
So I added the following static entry... looks fine?
/ip dns static add cname=sea.source.kernel.org name=geo.source.kernel.org type=CNAME
However, after adding the entry, resolving git.kernel.org. results into a failure.
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 62647
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
Since it's a SERVFAIL, my first thought was to check the DNS settings, and I found out that the Dnyamic Servers list was empty, which was supposed to be DNS Servers from PPPoE and DHCPv6 Clients.
Even if I readded static DNS servers manually, while other resolving works fine, git.kernel.org. still resolves to the same result as I didn't add the static entry.
For now, I have to flatten the CNAME chain, add a CNAME entry sea.source.kernel.org directly for git.kernel.org instead of geo.source.kernel.org, which also means I have to do the same thing for all domains which resolves to geo.source.kernel.org. like lore.kernel.org. and so, since they're still resolving to the server on the congested link. Also, hoping that no domain will have a CNAME to git.kernel.org., or it'll crash the RouterOS DNS Server again.
Bridge Hardware Offloading and IGMP Snooping enabled together breaks IPv6 Router Solicitations
The second one is just submitted through the service desk, so I'll just copy the content from there. MikroTik SUP-193239.
Symptom
  1. On RB5009UG+S+, Enable IGMP Snooping on a bridge whose ports are Hardware Offloaded.
  2. Create a static MDB entry (Bridge IGMP/MLD snooping - RouterOS - MikroTik Documentation) for Link-Local scope All Routers Address (ff02::2) on all VLANs and ports (including the bridge interface itself) on the bridge.
  3. Connect devices to the bridge, devices send Router Solicitation Messages to the all-routers multicast address (ff02::2), but never receive solicited Router Advertisement Messages. Packet sniffing shows Router Solicitation Messages are never forwarded to the bridge port of the router, even with the static MDB entry in place. IPv6 SLAAC is half-broken by now, since only unsolicited Router Advertisement Messages are sent out from time to time.
  4. Disable Hardware Offload on the port which will receive Router Solicitation Messages from the devices. Now Router Solicitation Messages will be forwarded to the bridge port of the router, and solicited Router Advertisement Messages are sent out. IPv6 SLAAC is working by now.
It seems that the problem has been reported previously, like Enabling IGMP snooping destablizes my network - #6 by gfunkdave .
The workaround for now seems to be disable Bridge Hardware Offloading when enabling IGMP Snooping.
This issue appears only after I switched to RB5009UG+S+ from RB4011iGS+, mainly caused by the RTL8367 switch chip on RB4011iGS+ doesn't support Bridge Hardware Offloading with IGMP Snooping enabled.
And even with Bridge Hardware Offloading disabled, Neighbor Solicitation Messages are still not flooded, thus breaking IPv6, as in Clients lose IPv6-Connectivity after a few minutes - RouterOS / General - MikroTik community forum. Seems that disabling MLD querier in the network solves the problem.
I doubt this. You’ll see after a while that it would stop working again :wink:. On my RB5009 I tried everything for the past couple of years and already gave up. You’ll need an external device (a smart switch maybe) that can act as querier, or just disable IGMP Snooping for now if you also use IPv6 and VLANs.
Yes, you’re correct, RS/RA messages are gone now. I have CRS309-1G-8S+ and CRS326-24G-2S+ in my network, but when I enable MLD Querier on one of them, Neighbor Solicitation Messages are not flooded or even forwarded to the correct ports, giving me devices declaring IPv6 addresses available, but no packets inbound (since there’re no IPv6 Neighbor entries for them on the router).
(dup post removed)
And I gave up, removing IPTV (IPv4 Multicasting) from the bridge, turning off IGMP Snooping, everything returns to normal. Maybe I’ll try this configuration again when RouterOS v8 releases :slight_smile:
The first problem was fixed in 7.20beta7.
Some users say the second problem has been fixed in 7.20rc2, I don't really know, since for now I use switch rule instead of IGMP Snooping for IPTV...
/interface ethernet switch rule
add comment="China Telecom IPTV RTP" dst-address=233.18.204.0/255.255.255.0 \
    dst-port=5140 mac-protocol=ip new-dst-ports=ether6,sfp-sfpplus1 ports=\
    ether3 protocol=udp switch=switch1
add comment="China Telecom IPTV RTP" dst-address=239.0.0.0/255.192.0.0 \
The slaac/hardware offload/igmp snooping problem definitely still exists, at least on my CRS328 switch running 7.23 “stable”. If I turn off igmp snooping, slaac RA replies work fast and immediately. I’ll turn it back on and try just disabling offload on the port facing my router.
Thank you for this post, I wasted a bunch of time trying to figure out why it was not working…
Edit: Can confirm disabling hardware offload also works around the problem, but this makes my CRS328 basically unusable due to its puny single core CPU. I guess if I want working slaac I have to flood multicast everywhere, all the time. Oh well…
