Normally this works, you can use multiple remote peers that only differ in their ID and Mikrotik sorts that out just fine. So what exactly means that “mikrotik only checks the first one” - that the second one (t) never authenticates or that both (s as well as t) end up using the same identity row (s) and thus they interfere with each other?
Do both s and t peers use the same operating system and IPsec client or they are different? That may affect what they send as their own ID (initiator ID) and as the ID they expect your Mikrotik to “listen” at (Responder ID); Mikrotik first finds the peer row based on local and remote IP address and exchange mode, and then searches through all the identity rows linked to that peer row, matching on both my-id and remote-id.
hi dear sindy,tnx for your replay,
the “s” authenticates is ok from andriod 14 native vpn using ikev2/ipsec psk , which s is the ipsec identifier.
but the “t” with the all same config on same device, is not authenticates and the log say :identity not found for server:x.x.x.x peer: FQDN: t
So you take the Android 14 device currently configured as “s”, you only change the “s” to a “t” on it, and that is enough to make it fail to authenticate? Or it’s actually two distinct (but identical) phones you believe to differ only in the “s” and “t”?
Yes
First time i can connect on my Android device with ipsec identifier “s” and then i just change “s” to “t” and it failed.
Another test i have done is that for i then just change “s” to “u” on server , and again the connection connect with “u”
So i think just the first identifier checked by mikrotik.
OK, so if there is no difference between s and k except the name itself on the phone side, there must be some difference between the identity rows on the Mikrotik side, unless it’s (e.g.) s.s for “s” but ttt (no dot inside) for “t” - the matcher used to be quite sensitive to the formal side of things, so if the “fqdn” does not contain at least one dot and/or it contains any other symbols except letters, digits, minuses, and dots, it is considered invalid (not an FQDN) and therefore it is not used for the lookup.
No, I’m sure there is no typo.i try the id with number and still as the same.
Do you think is there any reason that may the mikrotik not check the second identity?
For example in peer configuration? Or in mode config?
The search in the identity table is done using the criteria I’ve listed above, so there is no reason why one row should be ignored. mode-config is an “output parameter” of an identity row, not a match one.
What does /ip ipsec identity export hide-sensitive show? What ROS version are you running?
Before eventually taking such extreme measures, enable logging using /system logging add topics=ipsec,!packet if you haven’t done that yet, then run /log print follow-only file=working where topics~“ipsec”, and let the Android connect with the working settings. Then Ctrl-C the /log print …, download working.txt from the router, delete it there to free the space, run /log print follow-only file=failing where topics~“ipsec”, and let the Android try to connect with the wrong settings. After some 5 seconds, Ctrl-C the /log print …, and download the other file. If reading those files gives you no hint, you can use the information in this post to send me your contact info if you’d rather send me those files privately than obfuscate them and post them here (the IP addresses are encoded in the hex bytes shown so it is a bit more complicated to obfuscate than when the addresses only appear in the human friendly notation).
I have just tested the same setup on the responder side - fqdn:s and fqdn:t do work as expected if another Mikrotik acting as an initiator identifies itself using these identities. Each row of the identity list on the responder side refers to a different mode-config row with a different address and everything works as expected, the initiator gets the correct address depending on what my-id I set on its only identity row.
So it looks as if the Android was behaving different in some regard - mine is 12 so I have to use an app for IKEv2 that does not support pre-shared key authentication, hence testing on it would not be relevant. It also seems that Mikrotik does not care about the formal correctness of the FQDN IDs any more.
if I set on android “IPSec Identifier” user1, I connect succesfully.
if I set on android “IPSec Identifier” user2, connection doesnt work
I want to have different preshared keys for user1 and user2. Is this even possible?
But if I set the same preshared key for both identities, id user2 still cannot connect
