I havent tested this on RouterOSv6, i wanted it from beging to work with RouterOSv7.
I’d recommend to change the profile as suggested first. But as there are many other users, don’t change the profile under /interface l2tp-server server  - instead, add a new profile with only-one=no  as a copy of the default one with another name, and use it only for the two /ppp secret  items representing the test clients.
Done by instructions, no change, server log below:
Jan/31/2022 15:42:50 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:42:50 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Host-Name="VergosDUE"
Jan/31/2022 15:42:50 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Assigned-Tunnel-ID=1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:42:50 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:42:50 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:42:50 l2tp,debug tunnel 6630 entering state: wait-ctl-conn
Jan/31/2022 15:42:50 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=0, nr=1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6630
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=6630, session-id=0, ns=1, nr=1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:42:50 l2tp,debug tunnel 6630 entering state: estabilished
Jan/31/2022 15:42:50 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=1, nr=2
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=6630, session-id=0, ns=2, nr=1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Call-Serial-Number=0
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:42:50 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=1, session-id=1, ns=1, nr=3
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=6630, session-id=1, ns=3, nr=2
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:42:50 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:42:50 l2tp,debug session 1 entering state: established
Jan/31/2022 15:42:50 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=2, nr=4
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet .22>: rcvd  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet    <magic 0xbf250b47>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet    <magic 0xf3207f1>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <name VergosDUE>
Jan/31/2022 15:42:50 l2tp,ppp,info,account log: VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:42:50 l2tp,ppp,info,account VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     S=60C5815CB5B1A59BE861544FB60B8DA4F939737D
Jan/31/2022 15:42:50 l2tp,ppp,info log: <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:42:50 l2tp,ppp,info <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <addr 172.16.163.252>
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:42:50 interface,info log: <l2tp-VergosDUE> detect UNKNOWN
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <addr 172.16.164.252>
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:8>
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet      80 57 01 01 00 0e 01 0a 00 00 00 00 00 00 00 08
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CCP ConfReq id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet     <mppe 1000040>
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x80fd
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x3
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet      80 fd 01 01 00 0a 12 06 01 00 00 40
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:42:50 l2tp,ppp,info log: <l2tp-VergosDUE>: connected
Jan/31/2022 15:42:50 l2tp,ppp,info <l2tp-VergosDUE>: connected
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x2
Jan/31/2022 15:42:50 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x2
Jan/31/2022 15:42:50 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:08 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:08 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Host-Name="VergosUNO"
Jan/31/2022 15:43:08 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Tunnel-ID=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:08 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:08 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:08 l2tp,debug tunnel 6631 entering state: wait-ctl-conn
Jan/31/2022 15:43:08 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6631
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6631, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:08 l2tp,debug tunnel 6631 entering state: estabilished
Jan/31/2022 15:43:08 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6631, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Call-Serial-Number=0
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:08 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=1, ns=1, nr=3
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6631, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:08 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:08 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=1, ns=2, nr=4
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:08 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:08 l2tp,ppp,info log: <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:08 l2tp,ppp,info <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:08 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6630, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:08 l2tp,ppp,info,account log: VergosDUE logged out, 18 2668 2466 46 43 from CLIENT.IP.ADD
Jan/31/2022 15:43:08 l2tp,ppp,info,account VergosDUE logged out, 18 2668 2466 46 43 from CLIENT.IP.ADD
Jan/31/2022 15:43:08 l2tp,ppp,info log: <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:08 l2tp,ppp,info <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:08 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Session-ID=2
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Call-Serial-Number=1
Jan/31/2022 15:43:08 l2tp,debug session 2 entering state: wait-connect
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=2, ns=3, nr=5
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6630, session-id=2, ns=5, nr=4
Jan/31/2022 15:43:08 l2tp,debug session 2 entering state: established
Jan/31/2022 15:43:08 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=4, nr=6
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in initial state
Jan/31/2022 15:43:08 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6631, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: sent  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: rcvd  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x2
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet    <magic 0x8d20d505>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet    <magic 0x652757cc>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x2
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6631, session-id=2, ns=5, nr=4
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=2, ns=4, nr=6
Jan/31/2022 15:43:08 l2tp,debug session 2 entering state: stopping
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x2
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet    <magic 0x7b7fdc14>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet    <magic 0x4fce7509>
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6630, session-id=0, ns=6, nr=5
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=5, nr=7
Jan/31/2022 15:43:08 l2tp,debug tunnel 6630 entering state: dead
Jan/31/2022 15:43:08 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:08 l2tp,debug session 2 entering state: dead
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <name VergosUNO>
Jan/31/2022 15:43:08 interface,info log: <l2tp-VergosUNO> detect UNKNOWN
Jan/31/2022 15:43:08 l2tp,ppp,info,account log: VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:08 l2tp,ppp,info,account VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     S=C38FC2B754ECC6B1D59DD34B4E1A43061E63950B
Jan/31/2022 15:43:08 l2tp,ppp,info log: <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:08 l2tp,ppp,info <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <addr 172.16.163.251>
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <addr 172.16.164.251>
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:d>
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet      80 57 01 01 00 0e 01 0a 00 00 00 00 00 00 00 0d
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CCP ConfReq id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet     <mppe 1000040>
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x80fd
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x3
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet      80 fd 01 01 00 0a 12 06 01 00 00 40
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:08 l2tp,ppp,info log: <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:08 l2tp,ppp,info <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x2
Jan/31/2022 15:43:08 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x2
Jan/31/2022 15:43:08 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Host-Name="VergosDUE"
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Tunnel-ID=2
Jan/31/2022 15:43:08 l2tp,debug tunnel 6632 entering state: wait-ctl-conn
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6632
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6632, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:08 l2tp,debug tunnel 6632 entering state: estabilished
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6632, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Assigned-Session-ID=3
Jan/31/2022 15:43:08 l2tp,debug,packet     (M) Call-Serial-Number=2
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=2, session-id=3, ns=1, nr=3
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=6632, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:08 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Assigned-Session-ID=2
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:09 l2tp,debug session 2 entering state: stopping
Jan/31/2022 15:43:09 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=6631, session-id=0, ns=6, nr=5
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:09 l2tp,ppp,info,account log: VergosUNO logged out, 1 62 38 7 5 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,info,account VergosUNO logged out, 1 62 38 7 5 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:09 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Assigned-Tunnel-ID=1
Jan/31/2022 15:43:09 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=1, session-id=0, ns=5, nr=7
Jan/31/2022 15:43:09 l2tp,debug tunnel 6631 entering state: dead
Jan/31/2022 15:43:09 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:09 l2tp,debug session 2 entering state: dead
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x3
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet    <magic 0x36a20f09>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet    <magic 0x2e3e8468>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x3
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:09 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Host-Name="VergosUNO"
Jan/31/2022 15:43:09 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Assigned-Tunnel-ID=2
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:09 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <name VergosDUE>
Jan/31/2022 15:43:09 l2tp,debug tunnel 6633 entering state: wait-ctl-conn
Jan/31/2022 15:43:09 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6633
Jan/31/2022 15:43:09 l2tp,ppp,info,account log: VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,info,account VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     S=692B6C52644EA33DBD8EE583E6746666012B126C
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <addr 172.16.163.252>
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:09 interface,info log: <l2tp-VergosDUE> detect UNKNOWN
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x3
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x3
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <addr 172.16.164.252>
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=6633, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:09 l2tp,debug tunnel 6633 entering state: estabilished
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x2
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:8>
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet      80 57 01 02 00 0e 01 0a 00 00 00 00 00 00 00 08
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x2
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x2
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=6633, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Assigned-Session-ID=3
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Call-Serial-Number=2
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:09 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x4
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x4
Jan/31/2022 15:43:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=2, session-id=3, ns=1, nr=3
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=6633, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:09 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:09 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=2, session-id=3, ns=2, nr=4
Jan/31/2022 15:43:09 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:09 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:09 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=6632, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:09 l2tp,ppp,info,account log: VergosDUE logged out, 0 52 38 6 5 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,info,account VergosDUE logged out, 0 52 38 6 5 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:09 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:09 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=3, nr=5
Jan/31/2022 15:43:09 l2tp,debug tunnel 6632 entering state: dead
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet    <magic 0x49bd6e29>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet    <magic 0x52f02e78>
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <name VergosUNO>
Jan/31/2022 15:43:09 interface,info log: <l2tp-VergosUNO> detect UNKNOWN
Jan/31/2022 15:43:09 l2tp,ppp,info,account log: VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,info,account VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     S=5B77C6B7999E63879324AE2B9CC6566829368F38
Jan/31/2022 15:43:09 l2tp,ppp,info log: <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:09 l2tp,ppp,info <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:09 l2tp,ppp,debug,packet     <addr 172.16.163.251>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x3
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x3
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <addr 172.16.164.251>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x2
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:d>
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet      80 57 01 02 00 0e 01 0a 00 00 00 00 00 00 00 0d
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x2
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x2
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <addr 172.16.163.251>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:10 l2tp,ppp,info log: <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:10 l2tp,ppp,info <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x4
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x4
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:10 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:10 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Host-Name="VergosDUE"
Jan/31/2022 15:43:10 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Assigned-Tunnel-ID=3
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:10 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:10 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:10 l2tp,debug tunnel 6634 entering state: wait-ctl-conn
Jan/31/2022 15:43:10 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6634
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=6634, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:10 l2tp,debug tunnel 6634 entering state: estabilished
Jan/31/2022 15:43:10 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=6634, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Assigned-Session-ID=4
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Call-Serial-Number=3
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:10 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=3, session-id=4, ns=1, nr=3
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=6634, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:10 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:10 l2tp,ppp,info log: <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:10 l2tp,ppp,info <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:10 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=2, session-id=3, ns=2, nr=4
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:10 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:10 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=6633, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:10 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:10 l2tp,debug,packet     (M) Assigned-Tunnel-ID=2
Jan/31/2022 15:43:10 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:10 l2tp,debug,packet     tunnel-id=2, session-id=0, ns=3, nr=5
Jan/31/2022 15:43:10 l2tp,debug tunnel 6633 entering state: dead
Jan/31/2022 15:43:10 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:10 l2tp,ppp,info,account log: VergosUNO logged out, 1 52 38 6 5 from CLIENT.IP.ADD
Jan/31/2022 15:43:10 l2tp,ppp,info,account VergosUNO logged out, 1 52 38 6 5 from CLIENT.IP.ADD
Jan/31/2022 15:43:10 l2tp,ppp,info log: <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:10 l2tp,ppp,info <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x4
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet    <magic 0xf29fba1b>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet    <magic 0x77b9da44>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x4
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <name VergosDUE>
Jan/31/2022 15:43:10 l2tp,ppp,info,account log: VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:10 l2tp,ppp,info,account VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     S=45235A9EABC9835C88520CBA9F29785EF95FFFBA
Jan/31/2022 15:43:10 l2tp,ppp,info log: <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:10 l2tp,ppp,info <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <addr 172.16.163.252>
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:10 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:10 interface,info log: <l2tp-VergosDUE> detect UNKNOWN
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x5
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x5
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <addr 172.16.164.252>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x3
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:8>
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet      80 57 01 03 00 0e 01 0a 00 00 00 00 00 00 00 08
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x3
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x3
Jan/31/2022 15:43:10 l2tp,ppp,info log: <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:10 l2tp,ppp,info <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x6
Jan/31/2022 15:43:10 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x6
Jan/31/2022 15:43:11 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:11 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Host-Name="VergosUNO"
Jan/31/2022 15:43:11 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Assigned-Tunnel-ID=3
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:11 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:11 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:11 l2tp,debug tunnel 6635 entering state: wait-ctl-conn
Jan/31/2022 15:43:11 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6635
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=6635, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:11 l2tp,debug tunnel 6635 entering state: estabilished
Jan/31/2022 15:43:11 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=6635, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Assigned-Session-ID=4
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Call-Serial-Number=3
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:11 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=3, session-id=4, ns=1, nr=3
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=6635, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:11 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:11 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=3, session-id=4, ns=2, nr=4
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:11 l2tp,ppp,info log: <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:11 l2tp,ppp,info <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:11 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:11 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=6634, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:11 l2tp,ppp,info,account log: VergosDUE logged out, 1 52 230 6 8 from CLIENT.IP.ADD
Jan/31/2022 15:43:11 l2tp,ppp,info,account VergosDUE logged out, 1 52 230 6 8 from CLIENT.IP.ADD
Jan/31/2022 15:43:11 l2tp,ppp,info log: <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:11 l2tp,ppp,info <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:11 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:11 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:11 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=3, nr=5
Jan/31/2022 15:43:11 l2tp,debug tunnel 6634 entering state: dead
Jan/31/2022 15:43:11 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x4
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet    <magic 0xc02d325f>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet    <magic 0x74e43b54>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x4
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <name VergosUNO>
Jan/31/2022 15:43:11 l2tp,ppp,info,account log: VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:11 l2tp,ppp,info,account VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     S=B9C47C74BAA2D9793C5525719CFA1D8076913B99
Jan/31/2022 15:43:11 l2tp,ppp,info log: <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:11 l2tp,ppp,info <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <addr 172.16.163.251>
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:11 interface,info log: <l2tp-VergosUNO> detect UNKNOWN
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x5
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x5
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <addr 172.16.164.251>
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x3
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:d>
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet      80 57 01 03 00 0e 01 0a 00 00 00 00 00 00 00 0d
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x3
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x3
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:11 l2tp,ppp,info log: <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:11 l2tp,ppp,info <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x6
Jan/31/2022 15:43:11 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x6
Jan/31/2022 15:43:11 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:12 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:12 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Host-Name="VergosDUE"
Jan/31/2022 15:43:12 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Assigned-Tunnel-ID=4
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:12 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:12 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:12 l2tp,debug tunnel 6636 entering state: wait-ctl-conn
Jan/31/2022 15:43:12 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6636
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=6636, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:12 l2tp,debug tunnel 6636 entering state: estabilished
Jan/31/2022 15:43:12 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=6636, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Assigned-Session-ID=5
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Call-Serial-Number=4
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:12 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=4, session-id=5, ns=1, nr=3
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=6636, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:12 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:12 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=3, session-id=4, ns=2, nr=4
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:12 l2tp,ppp,info log: <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:12 l2tp,ppp,info <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:12 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:12 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=6635, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:12 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:12 l2tp,debug,packet     (M) Assigned-Tunnel-ID=3
Jan/31/2022 15:43:12 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:12 l2tp,debug,packet     tunnel-id=3, session-id=0, ns=3, nr=5
Jan/31/2022 15:43:12 l2tp,debug tunnel 6635 entering state: dead
Jan/31/2022 15:43:12 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:12 l2tp,ppp,info,account log: VergosUNO logged out, 1 481 482 11 12 from CLIENT.IP.ADD
Jan/31/2022 15:43:12 l2tp,ppp,info,account VergosUNO logged out, 1 481 482 11 12 from CLIENT.IP.ADD
Jan/31/2022 15:43:12 l2tp,ppp,info log: <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:12 l2tp,ppp,info <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:12 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x5
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet    <magic 0xdbde9519>
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet    <magic 0x34508824>
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:12 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x5
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet    <magic 0x34508824>
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <name VergosDUE>
Jan/31/2022 15:43:13 interface,info log: <l2tp-VergosDUE> detect UNKNOWN
Jan/31/2022 15:43:13 l2tp,ppp,info,account log: VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:13 l2tp,ppp,info,account VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     S=FB6B5350F5981E06DFA4B2F1085C11FEC6709E7C
Jan/31/2022 15:43:13 l2tp,ppp,info log: <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:13 l2tp,ppp,info <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <addr 172.16.163.252>
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x7
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x7
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <addr 172.16.164.252>
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x4
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:8>
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet      80 57 01 04 00 0e 01 0a 00 00 00 00 00 00 00 08
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x4
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x4
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:13 l2tp,ppp,info log: <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:13 l2tp,ppp,info <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x8
Jan/31/2022 15:43:13 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x8
Jan/31/2022 15:43:13 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:14 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:14 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Host-Name="VergosUNO"
Jan/31/2022 15:43:14 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Assigned-Tunnel-ID=4
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:14 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:14 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:14 l2tp,debug tunnel 6637 entering state: wait-ctl-conn
Jan/31/2022 15:43:14 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6637
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=6637, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:14 l2tp,debug tunnel 6637 entering state: estabilished
Jan/31/2022 15:43:14 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=6637, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Assigned-Session-ID=5
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Call-Serial-Number=4
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:14 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=4, session-id=5, ns=1, nr=3
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=6637, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:14 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:14 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=4, session-id=5, ns=2, nr=4
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:14 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:14 l2tp,ppp,info log: <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:14 l2tp,ppp,info <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:14 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=6636, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:14 l2tp,ppp,info,account log: VergosDUE logged out, 1 422 482 10 12 from CLIENT.IP.ADD
Jan/31/2022 15:43:14 l2tp,ppp,info,account VergosDUE logged out, 1 422 482 10 12 from CLIENT.IP.ADD
Jan/31/2022 15:43:14 l2tp,ppp,info log: <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:14 l2tp,ppp,info <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:14 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:14 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:14 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=3, nr=5
Jan/31/2022 15:43:14 l2tp,debug tunnel 6636 entering state: dead
Jan/31/2022 15:43:14 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x5
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet    <magic 0x8168ba75>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet    <magic 0x42438b48>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x5
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <name VergosUNO>
Jan/31/2022 15:43:14 l2tp,ppp,info,account log: VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:14 l2tp,ppp,info,account VergosUNO logged in, 172.16.164.251 from CLIENT.IP.ADD
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     S=F615053DD3703A497A276EA3E01B366A8979DAB8
Jan/31/2022 15:43:14 l2tp,ppp,info log: <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:14 l2tp,ppp,info <l2tp-VergosUNO>: authenticated
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <addr 172.16.163.251>
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:14 interface,info log: <l2tp-VergosUNO> detect UNKNOWN
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x7
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x7
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <addr 172.16.164.251>
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x4
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:d>
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet      80 57 01 04 00 0e 01 0a 00 00 00 00 00 00 00 0d
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x4
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x4
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:14 l2tp,ppp,info log: <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:14 l2tp,ppp,info <l2tp-VergosUNO>: connected
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x8
Jan/31/2022 15:43:14 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0x8
Jan/31/2022 15:43:14 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:17 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:17 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Host-Name="VergosDUE"
Jan/31/2022 15:43:17 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Assigned-Tunnel-ID=5
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:17 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:17 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:17 l2tp,debug tunnel 6638 entering state: wait-ctl-conn
Jan/31/2022 15:43:17 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6638
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=6638, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:17 l2tp,debug tunnel 6638 entering state: estabilished
Jan/31/2022 15:43:17 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=6638, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Assigned-Session-ID=6
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Call-Serial-Number=5
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:17 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=5, session-id=6, ns=1, nr=3
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=6638, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:17 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:17 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=4, session-id=5, ns=2, nr=4
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:17 l2tp,ppp,info log: <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:17 l2tp,ppp,info <l2tp-VergosUNO>: terminating... - hungup
Jan/31/2022 15:43:17 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:17 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=6637, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:17 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:17 l2tp,debug,packet     (M) Assigned-Tunnel-ID=4
Jan/31/2022 15:43:17 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:17 l2tp,debug,packet     tunnel-id=4, session-id=0, ns=3, nr=5
Jan/31/2022 15:43:17 l2tp,debug tunnel 6637 entering state: dead
Jan/31/2022 15:43:17 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:17 l2tp,ppp,info,account log: VergosUNO logged out, 3 770 610 14 14 from CLIENT.IP.ADD
Jan/31/2022 15:43:17 l2tp,ppp,info,account VergosUNO logged out, 3 770 610 14 14 from CLIENT.IP.ADD
Jan/31/2022 15:43:17 l2tp,ppp,info log: <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:17 l2tp,ppp,info <l2tp-VergosUNO>: disconnected
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x6
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet    <magic 0xf2230e4a>
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet    <magic 0x4529c9b2>
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x6
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:17 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:17 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     <name VergosDUE>
Jan/31/2022 15:43:18 l2tp,ppp,info,account log: VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:18 l2tp,ppp,info,account VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     S=89D35BC3278C351A6BF0F3A360D36EF60661C751
Jan/31/2022 15:43:18 l2tp,ppp,info log: <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:18 l2tp,ppp,info <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     <addr 172.16.163.252>
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:18 interface,info log: <l2tp-VergosDUE> detect UNKNOWN
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0x9
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0x9
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     <addr 172.16.164.252>
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x5
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:8>
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet      80 57 01 05 00 0e 01 0a 00 00 00 00 00 00 00 08
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x5
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x5
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:18 l2tp,ppp,info log: <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:18 l2tp,ppp,info <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0xa
Jan/31/2022 15:43:18 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0xa
Jan/31/2022 15:43:18 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:43:21 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=0, session-id=0, ns=0, nr=0
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=SCCRQ
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Protocol-Version=0x01:00
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Framing-Capabilities=0x1
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Bearer-Capabilities=0x0
Jan/31/2022 15:43:21 l2tp,debug,packet     Firmware-Revision=0x1
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Host-Name="VergosUNO"
Jan/31/2022 15:43:21 l2tp,debug,packet     Vendor-Name="MikroTik"
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Assigned-Tunnel-ID=5
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Receive-Window-Size=4
Jan/31/2022 15:43:21 l2tp,info log: first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:21 l2tp,info first L2TP UDP packet received from CLIENT.IP.ADD
Jan/31/2022 15:43:21 l2tp,debug tunnel 6639 entering state: wait-ctl-conn
Jan/31/2022 15:43:21 l2tp,debug,packet sent control message to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=0, nr=1
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=SCCRP
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Host-Name="CCR-VergosCore"
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Assigned-Tunnel-ID=6639
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6639, session-id=0, ns=1, nr=1
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=SCCCN
Jan/31/2022 15:43:21 l2tp,debug tunnel 6639 entering state: estabilished
Jan/31/2022 15:43:21 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:11701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=1, nr=2
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6639, session-id=0, ns=2, nr=1
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=ICRQ
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Assigned-Session-ID=6
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Call-Serial-Number=5
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Bearer-Type=0x0
Jan/31/2022 15:43:21 l2tp,debug session 1 entering state: wait-connect
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=6, ns=1, nr=3
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=ICRP
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Assigned-Session-ID=1
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6639, session-id=1, ns=3, nr=2
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=ICCN
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Framing-Type=0x1
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Tx-Connect-Speed-BPS=100000000
Jan/31/2022 15:43:21 l2tp,debug session 1 entering state: established
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=2, nr=4
Jan/31/2022 15:43:21 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=6, ns=2, nr=4
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:43:21 l2tp,debug session 1 entering state: stopping
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:43:21 l2tp,ppp,info log: <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:21 l2tp,ppp,info <l2tp-VergosDUE>: terminating... - hungup
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6639, session-id=1, ns=4, nr=2
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=2, nr=5
Jan/31/2022 15:43:21 l2tp,debug session 1 entering state: dead
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:43:21 l2tp,debug tunnel 6639 entering state: stopping
Jan/31/2022 15:43:21 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6638, session-id=0, ns=4, nr=3
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:43:21 l2tp,ppp,info,account log: VergosDUE logged out, 3 798 738 16 16 from CLIENT.IP.ADD
Jan/31/2022 15:43:21 l2tp,ppp,info,account VergosDUE logged out, 3 798 738 16 16 from CLIENT.IP.ADD
Jan/31/2022 15:43:21 l2tp,ppp,info log: <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:21 l2tp,ppp,info <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:43:21 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Assigned-Session-ID=7
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Call-Serial-Number=6
Jan/31/2022 15:43:21 l2tp,debug session 2 entering state: wait-connect
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=7, ns=3, nr=5
Jan/31/2022 15:43:21 l2tp,debug,packet     (M) Assigned-Session-ID=2
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in initial state
Jan/31/2022 15:43:21 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:11701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6639, session-id=0, ns=5, nr=3
Jan/31/2022 15:43:21 l2tp,debug tunnel 6639 entering state: dead
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=6638, session-id=2, ns=5, nr=4
Jan/31/2022 15:43:21 l2tp,debug session 2 entering state: established
Jan/31/2022 15:43:21 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:43:21 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=4, nr=6
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerup
Jan/31/2022 15:43:21 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP open
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfReq id=0x7
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet    <mru 1450>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet    <magic 0x63de2b78>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfReq id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet    <magic 0x323c94c2>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet    <auth  mschap2>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ConfAck id=0x7
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd LCP ConfAck id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP opened
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Challenge id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <challenge len=16>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <name CCR-VergosCore>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd CHAP Response id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <response len=49>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <name VergosDUE>
Jan/31/2022 15:43:22 interface,info log: <l2tp-VergosDUE> detect UNKNOWN
Jan/31/2022 15:43:22 l2tp,ppp,info,account log: VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:22 l2tp,ppp,info,account VergosDUE logged in, 172.16.164.252 from CLIENT.IP.ADD
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent CHAP Success id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     S=100C4A7E9B36316DBAB43FF80723DBE7724FD5F5
Jan/31/2022 15:43:22 l2tp,ppp,info log: <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:22 l2tp,ppp,info <l2tp-VergosDUE>: authenticated
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerup
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP open
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfReq id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <addr 172.16.163.252>
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP open
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerup
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP open
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfReq id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP open
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerup
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP open
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0xb
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <addr 0.0.0.0>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfNak id=0xb
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <addr 172.16.164.252>
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPV6CP ConfReq id=0x6
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet     <interface-identifier 0:0:0:8>
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: received unsupported protocol 0x8057
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP ProtRej id=0x2
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet      80 57 01 06 00 0e 01 0a 00 00 00 00 00 00 00 08
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfReq id=0x6
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent MPLSCP ConfAck id=0x6
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfAck id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd MPLSCP ConfAck id=0x1
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP opened
Jan/31/2022 15:43:22 l2tp,ppp,info log: <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:22 l2tp,ppp,info <l2tp-VergosDUE>: connected
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: rcvd IPCP ConfReq id=0xc
Jan/31/2022 15:43:22 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent IPCP ConfAck id=0xc
Jan/31/2022 15:43:22 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP opened
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP closed
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP lowerdown
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP lowerdown
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP down event in starting state
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP lowerdown
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPCP closed
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP lowerdown
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP down event in starting state
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP lowerdown
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: MPLSCP closed
Jan/31/2022 15:44:09 l2tp,ppp,debug,packet  <CLIENT.IP.ADD>: sent LCP TermAck id=0x8
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP lowerdown
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: CCP close
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: BCP close
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: IPV6CP close
Jan/31/2022 15:44:09 l2tp,ppp,info log: <l2tp-VergosDUE>: terminating...
Jan/31/2022 15:44:09 l2tp,ppp,info <l2tp-VergosDUE>: terminating...
Jan/31/2022 15:44:09 l2tp,ppp,debug <CLIENT.IP.ADD>: LCP down event in starting state
Jan/31/2022 15:44:09 l2tp,ppp,info,account log: VergosDUE logged out, 47 6386 6238 103 102 from CLIENT.IP.ADD
Jan/31/2022 15:44:09 l2tp,ppp,info,account VergosDUE logged out, 47 6386 6238 103 102 from CLIENT.IP.ADD
Jan/31/2022 15:44:09 l2tp,ppp,info log: <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:44:09 l2tp,ppp,info <l2tp-VergosDUE>: disconnected
Jan/31/2022 15:44:09 l2tp,debug,packet sent control message to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:44:09 l2tp,debug,packet     tunnel-id=5, session-id=7, ns=4, nr=6
Jan/31/2022 15:44:09 l2tp,debug,packet     (M) Message-Type=CDN
Jan/31/2022 15:44:09 l2tp,debug,packet     (M) Result-Code=1
Jan/31/2022 15:44:09 l2tp,debug,packet     (M) Assigned-Session-ID=2
Jan/31/2022 15:44:09 l2tp,debug session 2 entering state: stopping
Jan/31/2022 15:44:09 l2tp,debug,packet rcvd control message from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:44:09 l2tp,debug,packet     tunnel-id=6638, session-id=2, ns=6, nr=4
Jan/31/2022 15:44:09 l2tp,debug,packet     (M) Assigned-Session-ID=7
Jan/31/2022 15:44:09 l2tp,debug,packet sent control message (ack) to CLIENT.IP.ADD:21701 from PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:44:09 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=5, nr=7
Jan/31/2022 15:44:09 l2tp,debug session 2 entering state: dead
Jan/31/2022 15:44:09 l2tp,debug,packet rcvd control message (ack) from CLIENT.IP.ADD:21701 to PUBLIC.IP.VPN.SEVER:1701
Jan/31/2022 15:44:09 l2tp,debug,packet     tunnel-id=6638, session-id=0, ns=7, nr=5
Jan/31/2022 15:44:09 l2tp,debug,packet     (M) Message-Type=StopCCN
Jan/31/2022 15:44:09 l2tp,debug,packet     (M) Assigned-Tunnel-ID=5
Jan/31/2022 15:44:09 l2tp,debug,packet     tunnel-id=5, session-id=0, ns=5, nr=8
Jan/31/2022 15:44:09 l2tp,debug tunnel 6638 entering state: dead
Jan/31/2022 15:44:09 l2tp,debug session 1 entering state: dead
