two providers and static pool of external IP from one ofthem
Hi I have some problem with situation below:
ether1 - ISP1, IP: A.A.A.A/30
ether2 - ISP2, IP: B.B.B.B/30
ether3 - lan IP: 192.168.0.1/16 and C.C.C.1/24 and pool of external IPs from provider ISP2
I would like to use internet from provider ISP1 for computers from range 192.168.0.0/16 (NAT) and internet from provider ISP2 for computers with external IP.
my config:
/ip firewall mangle
add action=mark-routing chain=prerouting comment=“” disabled=no
new-routing-mark=to_ISP1 passthrough=no src-address=192.168.0.0/16
new-routing-mark=to_ISP2 passthrough=no src-address=C.C.C.0/24
add comment=“ISP1” disabled=no distance=1 dst-address=0.0.0.0/0
gateway=A.A.A.1 routing-mark=to_ISP1 scope=30 target-scope=10
add comment=“ISP2” disabled=no distance=1 dst-address=0.0.0.0/0
gateway=B.B.B.49 routing-mark=to_ISP2 scope=30 target-scope=10
add action=masquerade chain=srcnat comment=nat disabled=no
please helt because with this config nothing works.
Misha
Try changing your mangle rules:
/ip firewall mangle
add action=mark-connection chain=prerouting comment=“” disabled=no
new-connection-mark=mark_ISP1 passthrough=yes src-address=192.168.0.0/16
new-routing-mark=to_ISP1 passthrough=no connection-mark=mark_ISP1
new-connection-mark=mark_ISP2 passthrough=yes src-address=C.C.C.0/24
new-routing-mark=to_ISP2 passthrough=no connection-mark=mark_ISP2
That’s off the top of my head. The idea is that you mark the connection first, then mark the routing based on the connection mark.
Also, if your default route is through ISP1, there would be no need to mark for ISP1 at all (or vice versa). You only need to policy route for stuff that you don’t want using the default route.
