Two route with same gateway and dst-addres but different routing mark
With the following routes if I disable the route with comment loadbalancing1 the route check1 despite remains active, loses connectivity.
add comment=loadbalancing1 distance=1 gateway=10.0.0.1 routing-mark=wan1
add comment=loadbalancing2 distance=1 gateway=10.1.0.1 routing-mark=wan2
add comment=failover1 distance=1 gateway=10.0.0.1
add comment=failover2 distance=2 gateway=10.1.0.1
add comment=check1 distance=1 gateway=10.0.0.1 routing-mark=check1
add comment=check2 distance=1 gateway=10.1.0.1 routing-mark=check2
If the traffic has a routing mark, and the ‘active’ route is for a different routing mark, it wont route. You need to add separate routes with different priorities, so in fail over situation marked traffic still matches a route-
Something like this-
/ ip route add dst-address=0.0.0.0/ gateway=10.10.10.1 routing-mark=data distance=1 check-gateway=ping
/ ip route add dst-address=0.0.0.0/ gateway=192.168.10.1 routing-mark=voice distance=1 check-gateway=ping
/ ip route add dst-address=0.0.0.0/ gateway=10.10.10.1 routing-mark=voice distance=2 check-gateway=ping
/ ip route add dst-address=0.0.0.0/ gateway=192.168.10.1 routing-mark=data distance=2 check-gateway=ping
Bump
Bump
Bump
May I ask how are you testing your setup? What do you mean by “looses connectivity”?
Doing a ping from the routerboard with the routing mark that I want to test.
Try setting a correct src-address during ping, you may have some troubles if the packet is not masqueraded, for example.
In other words, the behavior is absurd as you are describing it, so I assume that since you are not disclosing the full picture, there are other reasons for the ping to timeout.
Also, you may want to observe the ping packets with the help of /tool sniffer to see if it actually goes out of the correct interface and in is has a correct src address set.
Why should I use src-address if I set already a routing mark?
Bump
Did you use sniffer to look at the packets?
you should set src-address on ping in case you have multiple ip addresses assigned to the router interfaces. In that case it would select some of the ip addresses and it may be one that is going to break your policy routing rules.
When I test in ping tool I set the routing mark I want to use in the advanced tab.
Bump
So, have you checked where exactly the packets go with the sniffer?
