Hi!
I have configured hairpin NAT so I don’t have to deal with split DNS. This has worked fairly well, but causes problems for me when I want to reach my web server 10.0.50.30 when I am connected over wireguard.
If I configure AllowedIPs to 0.0.0.0/0 it works fine, but usually I want split tunneling. Applying 10.0.0.0/16 in allowedIPs works as well for reaching my internal services. However my web server (10.0.50.30) is configured to accept traffic with a host header. Say “asd.test.com” as an example. In my imagination I thought I would be able to append my WAN IP to AllowedIPs, but then I can not reach anything in my /16 subnet (nor my web server for that matter). I assume this breaks because of some sort of routing loop. Maybe the handshake is routed into the new route?
Any suggestions to solve this while maintaining the hairpin NAT config?
add admin-mac=DC:2C:6E:0B:34:89 auto-mac=no comment=defconf name=bridge \
port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether2 ] comment=WiFi
set [ find default-name=ether5 ] comment=VMHost
set [ find default-name=sfp1 ] advertise="10M-baseT-half,10M-baseT-full,100M-ba\
seT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full"
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=sfp1 name=ISPWAN vlan-id=202
add interface=bridge name=bridge-vlan10-management vlan-id=10
add interface=bridge name=bridge-vlan50-server vlan-id=50
add interface=bridge name=bridge-vlan100-internal vlan-id=100
add interface=bridge name=bridge-vlan150-iot vlan-id=150
add interface=bridge name=bridge-vlan151-zaptec vlan-id=151
add interface=bridge name=bridge-vlan200-guest vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip dhcp-server option
add code=138 name=Omada-Controller value=0x0A00321E
/ip dhcp-server option sets
add name=omada options=Omada-Controller
add name=dhcp ranges=10.0.0.2-10.0.0.250
add name=l2tp_pool ranges=10.0.3.100-10.0.3.150
add name=dhcp_pool3 ranges=192.168.100.2-192.168.100.254
add name=vlan-200-guest-pool ranges=10.0.200.10-10.0.200.254
add name=vlan-151-zaptec-pool ranges=10.0.151.10-10.0.151.100
add name=vlan-10-management-pool ranges=10.0.10.100-10.0.10.254
add name=vlan-100-internal-pool ranges=10.0.100.10-10.0.100.254
add name=vlan-50-server-pool ranges=10.0.50.100-10.0.50.254
add name=vlan-150-iot-pool ranges=10.0.150.10-10.0.150.254
add name=VPN-POOL ranges=10.0.210.100-10.0.210.200
add address-pool=dhcp disabled=yes interface=bridge lease-time=10m name=\
LAN-dhcp
add address-pool=vlan-200-guest-pool interface=bridge-vlan200-guest \
lease-time=10m name=guest-dhcp
add address-pool=vlan-151-zaptec-pool interface=bridge-vlan151-zaptec \
lease-time=10m name=zaptec-dhcp
add address-pool=vlan-10-management-pool dhcp-option-set=omada interface=\
bridge-vlan10-management lease-time=10m name=management-dhcp
add address-pool=vlan-50-server-pool interface=bridge-vlan50-server \
lease-time=10m name=server-dhcp
add address-pool=vlan-100-internal-pool interface=bridge-vlan100-internal \
lease-time=10m name=internal-dhcp
add address-pool=vlan-150-iot-pool interface=bridge-vlan150-iot lease-time=10m \
name=iot-dhcp
/ip smb users
/port
set 0 name=serial0
/ppp profile
add bridge=bridge dns-server=10.0.0.1 local-address=10.0.3.1 name=L2TP-Profile \
remote-address=l2tp_pool
add dns-server=10.0.210.1 local-address=10.0.210.1 name=OPENVPN-PROFILE \
remote-address=VPN-POOL use-encryption=yes
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing pimsm instance
add afi=ipv4 disabled=no name=pimsm-instance1 vrf=main
/routing table
add disabled=yes fib name=wg-back
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10 pvid=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10 pvid=100
add bridge=bridge comment=defconf disabled=yes interface=sfp1 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=";;; defconf" interface=ether1 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=ether2,bridge vlan-ids=50
add bridge=bridge tagged=ether2,bridge untagged=ether4 vlan-ids=10
add bridge=bridge tagged=ether2,bridge untagged=ether5 vlan-ids=100
add bridge=bridge tagged=ether2,bridge vlan-ids=150
add bridge=bridge tagged=ether2,bridge vlan-ids=151
add bridge=bridge tagged=ether2,bridge vlan-ids=200
/interface l2tp-server server
set enabled=yes one-session-per-host=yes use-ipsec=required
add interface=ISPWAN list=WAN
add interface=bridge-vlan200-guest list=LAN
add interface=wireguard1 list=LAN
add interface=bridge-vlan151-zaptec list=LAN
add interface=bridge-vlan10-management list=LAN
add interface=ether5 list=LAN
add interface=bridge-vlan100-internal list=LAN
add interface=bridge-vlan50-server list=LAN
add interface=bridge-vlan150-iot list=LAN
/interface ovpn-server server
add auth=sha1 certificate=server@MikroTik-hEX-S cipher=aes128-gcm,aes256-gcm \
default-profile=OPENVPN-PROFILE disabled=no mac-address=FE:9D:73:63:56:86 \
name=ovpn-server1 require-client-certificate=yes
/interface wireguard peers
add allowed-address=192.168.200.3/32 interface=wireguard1 name=tyrkia \
public-key="lDckeSBt7Y8lFAQgC7EAF4haM1+xb3f0/CTnZL+mEwM="
add allowed-address=192.168.200.4/32 interface=wireguard1 name=work-laptop \
public-key="CTQ5I5fzp8Hrq8hRMbehdJiGKVyDVJFLKH7oEJMA5Ww="
add allowed-address=192.168.200.5/32 interface=wireguard1 name=iphone \
public-key="L0snMcGFnPrXzzSCI9RNInB5r5MpMj3nxOoffIcxqnE="
add allowed-address=192.168.200.6/32 interface=wireguard1 name=laptop \
public-key="DqU+48L/wGPYFsI5YeqoZofNTXXJkNPVz4jistMNRT8="
add allowed-address=192.168.200.7/32 interface=wireguard1 name=ipad \
public-key="/dxRzkxkkwvxL0PtD49GtyS5ZBmK4d61PwKktJVWEis="
add allowed-address=192.168.200.9/32 interface=wireguard1 name=work-lenovo \
public-key="eej1TTLDCQKWaGF0/u/AhAdcLTKKiKBmV+CU89O6k2M="
add address=192.168.100.1/24 comment="Guest address space" disabled=yes \
interface=*B network=192.168.100.0
add address=192.168.200.1/24 interface=wireguard1 network=192.168.200.0
add address=10.0.150.1/24 interface=bridge-vlan150-iot network=10.0.150.0
add address=10.0.0.1/24 interface=bridge network=10.0.0.0
add address=10.0.200.1/24 interface=bridge-vlan200-guest network=10.0.200.0
add address=10.0.151.1/24 interface=bridge-vlan151-zaptec network=10.0.151.0
add address=10.0.50.1/24 interface=bridge-vlan50-server network=10.0.50.0
add address=10.0.10.1/24 interface=bridge-vlan10-management network=10.0.10.0
add address=10.0.100.1/24 interface=bridge-vlan100-internal network=10.0.100.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add default-route-tables=main interface=ISPWAN
/ip dhcp-server lease
add address=10.0.50.15 client-id=\
ff:11:5d:24:63:0:1:0:1:2b:1b:c2:6d:16:a:bd:fb:7b:5b mac-address=\
52:BE:11:5D:24:63 server=server-dhcp
add address=10.0.50.30 client-id=\
ff:26:77:e7:a8:0:1:0:1:29:9c:32:0:9e:41:26:77:e7:a8 mac-address=\
9E:41:26:77:E7:A8 server=server-dhcp
add address=10.0.50.13 client-id=1:6e:b3:ec:b9:9f:6e mac-address=\
6E:B3:EC:B9:9F:6E server=server-dhcp
add address=10.0.10.234 client-id=1:e8:48:b8:56:b4:12 mac-address=\
E8:48:B8:56:B4:12 server=management-dhcp
add address=10.0.100.240 client-id=1:94:dd:f8:b:a3:cd mac-address=\
94:DD:F8:0B:A3:CD server=internal-dhcp
add address=10.0.50.147 client-id=\
ff:5d:e2:6c:15:0:2:0:0:ab:11:98:74:43:20:62:1c:28:57 mac-address=\
68:1D:EF:34:74:6C server=server-dhcp
add address=10.0.100.233 client-id=1:0:d4:9e:5f:99:16 mac-address=\
00:D4:9E:5F:99:16 server=internal-dhcp
add address=10.0.150.15 client-id=1:cc:5e:f8:aa:28:a8 mac-address=\
CC:5E:F8:AA:28:A8 server=iot-dhcp
add address=10.0.1.0/24 dns-server=10.0.50.30 gateway=10.0.1.1 netmask=24
add address=10.0.10.0/24 dns-server=\
213.184.200.1,213.184.200.2,213.184.210.210 gateway=10.0.10.1
add address=10.0.50.0/24 dns-server=\
213.184.200.1,213.184.200.2,213.184.210.210 gateway=10.0.50.1
add address=10.0.100.0/24 dns-server=10.0.50.30 gateway=10.0.100.1
add address=10.0.150.0/24 dns-server=10.0.50.30 gateway=10.0.150.1
add address=10.0.151.0/24 dns-server=1.1.1.1 gateway=10.0.151.1
add address=10.0.200.0/24 dns-server=10.0.50.30 gateway=10.0.200.1
add address=192.168.100.0/24 dns-server=1.1.1.1 gateway=192.168.100.1
set allow-remote-requests=yes mdns-repeat-ifaces="bridge-vlan200-guest,bridge-v\
lan100-internal,bridge-vlan150-iot,bridge-vlan10-management,bridge-vlan50-s\
erver" servers=213.184.200.1,213.184.200.2,213.184.210.210
/ip dns static
add address=10.0.10.1 comment=defconf name=router.lan type=A
add address=104.16.248.249 name=cloudflare-dns.com type=A
add address=104.16.249.249 name=cloudflare-dns.com type=A
add address=10.0.50.10 name=qnap.lan type=A
/ip firewall address-list
add address=d4500f0ca973.sn.mynetname.net list=WAN-IP
add address=192.168.200.4 list=asd-wireshark
add address=192.168.200.5 list=asd-wireshark
add address=10.0.0.0/16 list=all-lan-ranges
add address=192.168.200.0/24 list=all-lan-ranges
established,related,untracked
invalid
add action=accept chain=input comment=WIREGUARD dst-port=13231 in-interface=\
ISPWAN protocol=udp
"allow WireGuard traffic asdASDASDASDASDADS" disabled=yes src-address=\
192.168.200.0/24
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
connection-mark=!ipsec connection-state=established,related disabled=yes \
hw-offload=yes
add action=fasttrack-connection chain=forward comment=FastTrack \
connection-state=invalid
add action=accept chain=forward comment=DNS dst-address=10.0.50.30 dst-port=\
53,67 protocol=tcp
53,67 protocol=udp
add action=accept chain=forward comment="defconf: accept ICMP" in-interface=\
wireguard1 src-address=192.168.200.4
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward comment="defconf: allow internet traffic" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="L2TP Traffic out" out-interface-list=\
WAN src-address=10.0.3.0/24
add action=accept chain=forward comment="LAN to Guest" in-interface=bridge \
out-interface=bridge-vlan200-guest
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat connection-state=new
add action=accept chain=forward in-interface=bridge-vlan10-management \
out-interface=bridge-vlan50-server
out-interface=bridge-vlan100-internal
out-interface=bridge-vlan150-iot
add action=accept chain=forward in-interface=bridge-vlan50-server \
add action=accept chain=forward in-interface=bridge-vlan100-internal \
add action=accept chain=forward dst-address=10.0.10.237 dst-port=22,3389 \
in-interface=bridge-vlan100-internal protocol=tcp
add action=accept chain=forward in-interface=bridge-vlan200-guest \
add action=accept chain=forward dst-address=10.0.50.30 dst-port=443,80 \
in-interface=bridge-vlan200-guest protocol=tcp
add action=accept chain=forward dst-address=10.0.50.30 in-interface=\
bridge-vlan100-internal protocol=icmp
add action=accept chain=forward comment="Wireguard to webserver" dst-address=\
10.0.50.30 dst-port=443,80 in-interface=wireguard1 protocol=tcp
add action=accept chain=forward dst-address=10.0.10.237 in-interface=\
wireguard1
add action=accept chain=forward comment="Sonos -> Home Assistant" dst-address=\
10.0.50.13 dst-port=1400 in-interface=bridge-vlan150-iot protocol=tcp
add action=accept chain=forward comment="Access portainer from internal" \
dst-address=10.0.50.30 dst-port=9443 in-interface=bridge-vlan100-internal \
protocol=tcp
add action=accept chain=forward comment=redlib dst-address=10.0.50.30 \
dst-port=1337 in-interface=bridge-vlan100-internal protocol=tcp
add action=accept chain=forward in-interface=wireguard1 out-interface=\
wireguard1
out-interface=wireguard1
add action=accept chain=forward comment="openvpn out" disabled=yes \
out-interface-list=WAN src-address=10.0.210.0/24
add action=accept chain=forward dst-address=10.0.50.10 dst-port=445,139 \
add action=drop chain=forward comment="Drop anything else"
/ip firewall mangle
add action=change-mss chain=forward disabled=yes dst-address=172.30.100.0/24 \
new-mss=1400 protocol=tcp src-address=10.0.10.0/24 tcp-flags=syn tcp-mss=\
!0-1400
add action=mark-connection chain=forward comment="Mark IPsec" disabled=yes \
ipsec-policy=out,ipsec new-connection-mark=ipsec
ipsec-policy=in,ipsec new-connection-mark=ipsec
add action=accept chain=srcnat disabled=yes dst-address=172.30.100.0/24 \
add action=dst-nat chain=dstnat comment="hairpin nat" dst-address-list=WAN-IP \
dst-port=443 protocol=tcp to-addresses=10.0.50.30 to-ports=443
dst-port=80 protocol=tcp to-addresses=10.0.50.30 to-ports=80
add action=masquerade chain=srcnat dst-address=10.0.50.30 out-interface-list=\
LAN protocol=tcp src-address=10.0.50.0/24
add action=masquerade chain=srcnat comment="management out" \
out-interface-list=WAN src-address=10.0.10.0/24
add action=masquerade chain=srcnat comment="server network out" ipsec-policy=\
out,none out-interface-list=WAN src-address=10.0.50.0/24
add action=masquerade chain=srcnat comment="LAN out" out-interface-list=WAN \
src-address=10.0.100.0/24
add action=masquerade chain=srcnat comment="IOT network out" \
out-interface-list=WAN src-address=10.0.150.0/24
add action=masquerade chain=srcnat comment=zaptec-out out-interface-list=WAN \
src-address=10.0.151.0/24
add action=masquerade chain=srcnat comment="Guest network out" \
out-interface-list=WAN src-address=10.0.200.0/24
add action=masquerade chain=srcnat comment="VPN out" out-interface-list=WAN \
src-address=192.168.200.0/24
add action=masquerade chain=srcnat comment="openVPN out" out-interface-list=\
add action=dst-nat chain=dstnat comment="traefik http" dst-address-list=WAN-IP \
add action=dst-nat chain=dstnat comment="traefik https" dst-address-list=\
WAN-IP dst-port=443 protocol=tcp to-addresses=10.0.50.30 to-ports=443
add action=dst-nat chain=dstnat comment=torrents dst-port=13339 \
in-interface-list=WAN protocol=tcp src-address-list="" to-addresses=\
10.0.50.30 to-ports=13339
add action=dst-nat chain=dstnat comment=plex dst-address-list=WAN-IP dst-port=\
32400 protocol=tcp to-addresses=10.0.50.30 to-ports=32400
add action=masquerade chain=srcnat comment="L2TP out" out-interface-list=WAN \
add disabled=yes distance=1 dst-address=10.0.210.0/24 gateway=10.0.210.1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=yes distance=1 dst-address=172.30.100.0/24 gateway=10.0.0.1 \
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 \
routing-table=wg-back scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=0.0.0.0/0 gateway="" routing-table=main \
/ip service
set telnet address=10.0.0.0/16
set ftp address=10.0.0.0/16
set www address=10.0.0.0/16
set ssh address=10.0.0.0/16
set api address=10.0.0.0/16
set winbox address=10.0.0.0/16
set api-ssl address=10.0.0.0/16
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/ppp secret
add name=min profile=L2TP-Profile service=l2tp
add disabled=yes name=sinmid profile=L2TP-Profile service=l2tp
add name=sin profile=OPENVPN-PROFILE service=ovpn
/routing bfd configuration
add disabled=no
/routing igmp-proxy interface
add disabled=yes interface=bridge upstream=yes
add disabled=yes interface=*D
add disabled=yes interface=bridge-vlan200-guest
/routing pimsm interface-template
add disabled=no instance=pimsm-instance1 interfaces=bridge
add disabled=no instance=pimsm-instance1 interfaces=bridge-vlan200-guest
/routing rule
add action=lookup-only-in-table disabled=no min-prefix=0 table=main
add action=lookup disabled=yes src-address=192.168.200.9/32 table=wg-back
/system clock
set time-zone-name=Europe/Oslo
/system identity
set name=MikroTik-hEX-S
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/tool bandwidth-server
set authenticate=no enabled=no
/tool graphing interface
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
/tool sniffer
set filter-interface=wireguard1 filter-ip-address=192.168.200.9/32
