Unable to create IPSec Tunnel between 3011 & 4011
Hi all,
I Setup a RB4011iGS+ a few weeks ago, to replace an overloaded 3011UiAS. Everything went fine except our GRE/IPsec tunnel between this router and another 3011UiAS located in a different data-center room.
We got this in the distant 3011's log:
phase1 negotiation failed due to time up <3011's IP>[500]<=><4011's IP>[500] 1ab84487cc1a4ee9:20e8b7c03c9260d2
Back in the lab, I setup the "faulty" 4011, a spare 3011 with a backed up production configuration, connected the two using a little switch to my pc, which acted as a router for the two MikroTiks. Ping works fine in both ways, but I still get the same "phase1 negotiation failed due to time up" on every router. I disabled every "drop" rule on the firewall, but no luck. However in the #IP:Firewall.Connections page I can see the connection as "C" (Confirmed), but with no S (Reply)...
Here is the IPSec part of the 4011 router:
[admin@4011] > /interface eoip print
 0    name="eoip2" mtu=auto actual-mtu=1458 l2mtu=65535 mac-address=XXXXXXXX arp=enabled arp-timeout=1m loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m local-address=XXXXXXXX remote-address=XXXXXXXX tunnel-id=1 keepalive=10s,10
      dscp=inherit clamp-tcp-mss=yes dont-fragment=inherit ipsec-secret="XXXXXXXX" allow-fast-path=no
[admin@4011] > /ip ipsec export
# sep/02/2020 11:55:08 by RouterOS 6.45.9
# software id = XXXXXXXX
# model = RB4011iGS+
# serial number = XXXXXXXX
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-256,aes-192,aes-128
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des
[admin@4011] > /ip ipsec identity print
Flags: D - dynamic, X - disabled
 0 D  ;;; eoip2
      peer=eoip2 auth-method=pre-shared-key secret="XXXXXXXX" generate-policy=no
Here is the 3011 one:
[admin@3011] > /interface eoip print
 0    name="eoip1" mtu=auto actual-mtu=1458 l2mtu=65535 mac-address=XXXXXXXX arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m local-address=XXXXXXXX remote-address=XXXXXXXX tunnel-id=1 keepalive=10s,10
[admin@3011] > /ip ipsec export
# sep/02/2020 11:57:41 by RouterOS 6.45.9
# model = RouterBOARD 3011UiAS
/ip ipsec profile
/ip ipsec proposal
[admin@3011] >  /ip ipsec identity print
  0 D  ;;; eoip1
      peer=eoip1 auth-method=pre-shared-key secret="XXXXXXXX" generate-policy=no
As you can see this is pretty much the same. I must be missing something (I must admit I'm a newbie in the MikroTik world - I'm more used to Cisco hardware), but what...
All 3011 routers in production are running RouterOS 6.35.2, the 4011 one is running latest long-term (6.45.9), I upgraded the 3011 router in the lab to 6.45.9 too but nothing changes.
Any help will be much appreciated there. I can post other parts of the configuration if needed.
Thanks in advance,
Nicolas
It seems to be more a network issue than a EoIP one: using the same LAN (10.10.10.0/24) for the “public” IPs, the tunnel goes up fine. I may have messed up something with my lab setup. Thing is, we have the same issue in a real environment when plugging the 4011 router at the data-center.
Does anybody knows what could be causing the same issue in production? only hardware is different from the previous router, even mac addresses are the same…
according to the firewall logs, The outgoing IP was not the one allowed for GRE tunneling, despite the fact that the IP was indeed defined in the eoip interface configuration (!?)
I’ve upgraded the firmware to latest stable release (I was running long-term), and it seems to work better. Hope it will fix this mess for good!
