Hello
when I try to install a container, I get this error
error code getting container config: 400
error parsing container config
was unable to import, container 4c9aac65-8d50-4270-aae2-6430d6564f05
You should get: finished
Where url placeholders can be get from remote image format {namespace}/{repository}:{tag}, if {tag} is not specified latest is used.
For example for Pi-hole container namespace and repository are named pihole (pihole/pihole) and fetch url will be then: https://registry.hub.docker.com/v2/namespaces/pihole/repositories/pihole/tags/latest
I ran the command with a few repos and those finish. My problem seems to be no matter which container I try, Technitium/dns-server, PiHole (from wiki example) and even a docker hello-world for the purposes of no mounts, env being needed. In the logs I always get the same error was
unable to import, container 2eb2e36f-23ef-4ea5-b780-70fb6f0c25ac
This also was using the old registry that I mentioned before, and also the new one https://registry.hub.docker.com that was suggested. After trying a few different times I will then get
Not sure if this has to do with updating ROS as I had no problem running a container before on v7.16. (I just saved my old /container/add line from when I first created the container and tried to run it again)
It seems new ROS version issue if for same containers fetch command is not failing, maybe it is building docker hub API url wrong. Container debug logs did not help? Maybe there is a debug log from which url is trying to fetch when building container.
Enabling logging on the container didn’t provide any additional information sadly. I will upgrade to the ROS v7.18 beta and see if that makes a difference and report back.
Update - Upgrading to ROS v7.18 beta 5 fixed my problem ran the same command previously and now my container is running. I am no longer encountering the unable to import container. Looks like it’s just a bug with ROS v7.17
Yes I was, I tried technitium/dns-server:latest and even technitium/dns-server:latest@sha256:6f25ba81ad8be0019cb3d439d8452435614b40d2fe8252fced684eef277e2257 (I thought this might help as I seen in v7.18 there was a change about how containers choose the correct arch, didn’t know if v7.17 was grabbing the wrong arch which caused it to fail importing)
For fetching latest tagged remote image is not mandatory to specify tag, it will be added by default, you can see when container is created that it has :latest tag even it is not specified. At least it is behaving like that up to 7.16, not tried on newer versions.
It seems something is charged on Docker Hub API side, it no longer works also on ROS 7.16 which I’m using and probably on all lower versions than 7.18. Maybe because of Docker Hub API issues MT decided for 7.18 to switch default repository url to https://lscr.io which is not working on lower versions.
That is quite inconvenient for 16MB storage devices which cannot upgrade to 7.18 due to lack of free space on storage. Now only with manual upload of docker image is possible to add container… Very disappointing.
Also a possible bug, if you don’t have a registry set (blank) after upgrading to 7.18 beta 5, it doesn’t look like editing the registry via Winbox in container config will stick. I was able to confirm this by “/container/config print” as it still showed “assumed-registry-url: https://lscr.io” instead of the specific registry I put. Checking the container config (winbox, gui) after rebooting also showed that container config registry was empty.
After changing the registry via the terminal with the “/container/config set registry-url=” it look like it took and the registry was updated when running the “/container/config print” again. I was also able to confirm editing the registry via winbox gui was now working after at least setting it once via terminal.
Strange.
Update - Reported this issue to Mikrotik support@mikrotik.com. They were able to reproduce it and said it would be fixed on a later update.
Same problem on hAP ax^3 ROS 7.17.2
I have a working container that I installed in the previous version of ROS 7.16.x which starts and is fully functional, but I can’t install new ones after updating to 7.17.2
Wouldn’t experiment with 7.18 beta, taking into account that even the stable version is quite problematic.
Did anyone managed to solve this issue on 7.17.2?
